Business Card Holder
578
18
Published
Introduction: Business Card Holder
About: I am a Woodworking Hobbyist, I enjoy creating from what most people would consider scraps. To give new life to a piece of wood and give joy to someone with a Special Hand Made Gift.
Check out this video for more Details
Step 1: Business Card Holder
Create you own Business Card Hold with a single piece of Scrap. This was made with a piece of Mahogany. With a little resawing, and scroll work, you can make it as well.
Step 2:
Measure the Length you want the holder to be.
Step 3:
Cut your piece to the measurement
Step 4:
Mark the center point to resaw the board
Step 5:
resaw your marked line on the bandsaw
Step 6:
Plan down the resaw side smooth
Step 7:
glue up the 2 pieces
Step 8:
with spray adhesive , place your pattern to the board after glue has dried and sanded smooth
Step 9:
Scroll out your pattern
Step 10:
use a foster bit to cut the recess for the clock
Step 11:
Draw out you arms for the cards and cut out with the scroll saw or bandsaw
Step 12:
insert the 2 arms to your scroll work, and glue to the base
Step 13:
you can use a drinking straw to scoop out the glue squeeze out once it is clamped together
Step 14:
I used Semi Gloss Deft Spray lacquer as a finish
Step 15:
insert the clock to the recess you drilled
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    Hi Sterling
    This is Beautiful work my Friend. You make really nice projects, I might make one myself and add a pocket watch to it as I have a couple of them on my shelf. Thank you for sharing this Instructable. Take care.
