The attached archive is the contest entry as it was on my server, minus the images. The text is taken from the included document.
This PIC/EEPROM programmer is so simple and small it fits on a business card with enough room left for assembly instructions...
Project:
Simple JDM2 style PIC ICSP programmer (on a business card).
- all through hole
- less than 2USD worth of parts (in 1s and 2s!)
- easy single sided construction at home (with 3 jumpers)
- enough room left for assembly instructions
- extra space on the back for even more business-cardy goodness
- also programs/reads serial EEPROMS
Easy/beginner.
Assembly time:
About an hour.
hackaday.zip64 KB
Remove these ads by
Signing UpStep 1Description
The PCB can be made single sided (with three jumper wires), but a two layer design makes assembly even easier. All the traces are nice and fat for easy toner-transfer or photo-process at home.
The JDM2 design is quite old, the original JDM2 circuit can be found here:
http://www.jdm.homepage.dk/newpic.htm
This design stays true to the old schematic, but the diode numbering now starts at 1, rather than 2.
i'm starting muc world. and will start with this project. Did anyone test this project?
Thanx in advance,
Shane
(and you havent read it good enough)
the link u gave from the Understanding ICSP instructable said that this JDM2-style PIC Programmer has some problems with those type of PICs
http://www.belza.cz/digital/jdm.htm
I also noted he added some capacitors, does his modified version functions same as your circuit for F628A's and other PICs?
by the way, thanks very much for all your help, I understand ICSP a bit because of your instructables,
God Bless
Thanks
Thanks again
Thanks
http://www.instructables.com/files/orig/FQ8/KE6D/FXA3D43B/FQ8KE6DFXA3D43B.png
http://www.instructables.com/id/Understanding-ICSP-for-PIC-Microcontrollers/
