loading
Step 4: Assembly #2
Next, add the transistors. They should be oriented at show in the schematic/picture. The transistor on the left is placed in the direction opposite the transistor on the right (notice both have round parts facing the middle). This is the standard (typical?) BC547B pin-out. If you have problems with your finished circuit, make sure that your transistors have the same pin-out as shown in the schematic and reorient as needed.
<p>Hi there.It work gooood .</p><p>i add two led blue and red with 10k resistor for power from vdd and vpp</p><p>blue led always on and red led when programing</p><p>Itest it with 16f877 12f675 16f64<br></p>
I was wonder of you knew how to program reward / loyalty cards?
Hi guys, im trying to make this on a budget. The clad boards seem a tad expensive, and lots of labor in making it. Bottom line is i was going to make this on a piece of cardboard or something similar. <br> <br>I have a question however how exactly do grounds work on circuit boards? Ground is just a piece of metal that all componets requiring ground need to touch to? Does this ground require anything outside of that, for example the DB9 is that grounded to the PCB ground as well, and in turn does the DB9 somehow ground the PCB to the computer? <br> <br>In otherwords is there anything special i need to do because im using cardboard instead of clad? <br> <br>Lastly i noticed an explosion warning in the document and placing a diode between the programmer (this pic programmer i assume) and the system (the computers DB9 i assume), just for clarification where exactly do i put this diode and why wasn't it simply put into the PCB design? I assume this is in regards to just programming a pic. I also see mention of master clear and a resistor, i assume the resistor isn't needed unless i need to clear the pic due to some error programming it. <br> <br>Anyways im obviously a noob just getting my feet wet so could use a bit of help
Hi. First off, thanks to Ian for a great Instructable. I have just constructed this circuit and am trying to do the hello world of PIC programming (The lit LED). this is my first attempt at PIC programming and Im fairly new to electronics also.<br> <br> The circuit seems to be constructed properly, I am using a desktop tower with COM1 port and under Linux, running the command line version of picpgm. Picpgm autodetects it as a JDM programmer and I tell it to read the PIC to verify if it is blank or not. I get an error<br> <br> &quot;picpgm: /home/christian/picpgm_1751/picpgm/src/common/pic10fxxx.cpp:640: virtual UINT32 CPic10Fxxx::GetOSCCAL(): Assertion `(m_nOSCCAL &amp; 0x0F00) == 0x0C00' failed.&quot;<br> <br> I then went back and measured the voltage across the VSS pin and VPP pin whilst it is trying to program/read the PIC, It was 15.2V, quite high considering most people seem to report problems where they have too low a voltage here.<br> <br> BUT; then something very odd happened, whilst I had the multimeter pressed against the VSS and VPP pins, measuring the DC voltage, the programmer worked!! I was able to read the chip, what's more, I was actually able to program the chip (as long as I had my multimeter leads testing DC voltage between VSS and VPP throughout?!).<br> <br> Does anyone have any idea why that might be? I thought it might be impedence, so tried a variety of 10M, 1M, 100K 22K resistors across VPP and VSS but that did not recreate the same effect as using the multimerer. Can anyone hazard a guess as to why my VPP voltage is also so high?<br> <br> The only difference to Ian's schematic is that for some reason I ended up with a 5.6V zener diode in mine as opposed to a 5.1V zener. I didnt think it would make that much difference to the voltage though. I also have an LED between D1 and Q1 to show when it is programming. Many other JDM circuits also have this LED in them so i didn't think it was a big deviation from the design.<br> <br> Any help appreciated. Thanks in advance, sorry for the length.
Hi, <br> I want to program PIC12F629 with readymade .hex code. Which programmer should I use? I would like to know the best and cheapest programmer available. I bought PICKIT2 clone from India but I had very bad experience with it. I couldn't program with it. <br> Can you please suggest me good programmer? <br>Regards, <br>Chetan
would a BC546B do it? I got an BC546B and BC557B but no BC547B X_X
I got the same question for the Diode... I got the PH4148, can I use this one?
No clue what a PH4148 is, but when googeling it all I get is that it is a Zener Diode, and in that case, NO it will not work. <br>Do you have the datasheet for your diode? <br> <br>You could use 1n4007 or similar diodes though.. what else have you got?
BC546 would do yes, NOT a BC557 as that is a PNP type transistor.
The most easiest Programmer i have found after researching! <br>Im not an expert in electronics, but i just want to Program PIC10F200 and PIC12F629, for an InfraRed Controlled Airplane. <br>Could you please tell me How to Connect the DB9 Cable to Laptop? My laptop doesnt seem to have a DB9 connection, not even my desktop computer. <br>I have a 15 pin connection. How to connect it?? Thank you.
Well if your laptop doesnt have a DB9 connector, obviously you need an adapter. Look for a USB to Serial adapter.
hi; <br>i'm starting muc world. and will start with this project. Did anyone test this project? <br>
Hi there, where have all the pdf's gone. I wanted to download the circuit to print it.
Hi there, forgive me but I'm new at electronics and I'm scratching the surface right now. Having said that, what is this used for? What is a PIC controller. What can you do with the device you built? Thanks very much and sorry for my lack of education.
A microcontroller is a small, programmable device that can interface with switches, LEDs, USB, ect.
Will this programmer work with all PIC's? I need to program a PIC16F684.
I built a programmer off of your schematic and it works great. Thank you! Now I can program newer PIC microchips without buying an expensive programmer.
How would I go about making this a usb programmer.<br><br>Thanx in advance,<br>Shane<br>
You can take this JDM programmer and load a bootloader program into a PIC with USB capabilities. Wire up the USB and use the bootloader program to load programs to the PIC over USB
can i use a 2N2222 NPN transistor instead of the BC547B?
so what good does this do?
its a PIC/EEPROM programmer
Does it <em>have</em> to be a tantalum capacitor? What difference would it make from a tantalum cap to an aluminum electrolytic cap?<br/>
Paanz asked this question below: Yes, as far as I know, C2 MUST be tantalum. Did you try something else? It would be interesting to confirm if the circuit worked/didnt work with other caps.
I tried this circuit on a breadboard with a 22uF electrolytic cap and BC547C transistors. I noticed that with this configuration the voltage on the dat pin is 3.3v with the data lines low and 9.5v with the data lines set to high. I am unsure if this is caused by the electrolytic capacitor as I have no tantalum capacitors to try out
I breadboarded this circuit with a 22uF Electrolytic, and it programmed the 18F2550, and 12F683 without issue (also a 16C745). I then proceeded to etch a board, presto I can program the 18F2550, but NOT the 683, the 16F84A wouldn't work either way. Just odd, but I'll get the Tantalum cap and try again! P.S. you should mention that fill layer button within Eagle. I have used Eagle on a few different occasions, but ended up making a manual fill because I didn't know about that fill button. Great Instructable, by the way!
I didn't build it yet, I am trying to see what parts I will need to buy, and which I have laying around. Before reading this, I have never heard of Tantalum capacitors, so I was wondering exactly why it needs to be one, and what the difference is between them and regular electrolytic caps.
they are made with tantalum, a superconducting metal that is not the most abundant metal ever.
Yea, I understand that, but that still doesn't explain to me why two different caps with the same value would have a different effect. idk though, unless maybe they charge and discharge at a different rate...
They do. Do a quick google for tantalum caps.
I know nothing about electronics. what does this do?
relay i dont beleve you know electronicks<br><br>(and you havent read it good enough)
I second this...
can I use it for PIC16F628A and Other 18-pin Low Voltage PIC? <br><br>the link u gave from the Understanding ICSP instructable said that this JDM2-style PIC Programmer has some problems with those type of PICs<br><br><br>http://www.belza.cz/digital/jdm.htm<br><br>I also noted he added some capacitors, does his modified version functions same as your circuit for F628A's and other PICs?<br><br>by the way, thanks very much for all your help, I understand ICSP a bit because of your instructables,<br><br>God Bless
could i use two 2n2222 transistors instead of these neded
Is this the proper way to connect a PIC12C508 to the programmer?&nbsp; If it is not, what is the correct way?<br /> <br /> Thanks<br />
VPP, VDD, and GND look fine. I can't tell from the graphic if data and clock are on the correct pins (PGD=data, pgc=clock).<br />
There is not a PGD or pgc on the datasheet for the PIC12C508, but there is a GP5/OSC1/CLKIN, a GP4/OSC2, a GP2/T0CKI, a GP0 and a GP1.&nbsp; Here is a link to the datasheet: http://www.datasheetsite.com/extpdf.php?q=http%3A%2F%2Fpdfdata.datasheetsite.com%2Fpdf1%2FMicrochip%2FPIC12LCE519T-04-SN.pdf <br /> <br /> Thanks again<br />
Check page 46 - ICSP. It looks like GP0 and GP1.<br />
Thanks<br />
How did you go about adding your skull image into Eagle? I have not been able to figure this out.<br /> <br /> Thanks<br />
Hey I was wondering if this breadboard layout I made is correct. The following link is to a .png format of the layout.<br/><br/><a rel="nofollow" href="http://www.instructables.com/files/orig/FQ8/KE6D/FXA3D43B/FQ8KE6DFXA3D43B.png">http://www.instructables.com/files/orig/FQ8/KE6D/FXA3D43B/FQ8KE6DFXA3D43B.png</a><br/>
I'm sorry, I'm not quite sure what the connections and symbols mean. Why don't you hook it up to a PC and see if ICPROG detects the JDM2? If that works, hook up to a PIC and try to program it. Use an old PC if you're worried about blowing the serial port.
Can anyone tell me if I have my experiment breadboard layout correct?<br/><br/><a rel="nofollow" href="http://www.instructables.com/files/orig/FQ8/KE6D/FXA3D43B/FQ8KE6DFXA3D43B.png">http://www.instructables.com/files/orig/FQ8/KE6D/FXA3D43B/FQ8KE6DFXA3D43B.png</a><br/>
So I'm guessing that all I have to do after making this is to connect the PIC to the corresponding pins on the programmer?
Can anyone enlighten me on what the current of the 5.1 V and 8.2 V diodes should be? I haven't been able to find it anywhere, and I want to order to build this. Thanks in advance.
I have found this instructable very useful. I am going to make this programmer, however, I do have one question before I begin. You labeled the five pins of the 5-pin header "VPP," "VDD," "VSS," "CLK," and "DAT." Could you let me know which pins on a PIC, say a PIC16F84, these would connect to. I already know VSS (the negative power), but I can't find any of the other four on a diagram of a PIC16F84. Any embellishment would be appreciated, as I am fairly new to electronics, but it is still kind of embarrassing that I don't know the answer to this. Thanks.
Try my Understanding ICSP for PIC Microcontrollers post<br/><br/><a href="http://www.instructables.com/id/Understanding-ICSP-for-PIC-Microcontrollers/">http://www.instructables.com/id/Understanding-ICSP-for-PIC-Microcontrollers/</a><br/>
About This Instructable
97,018views
178favorites
License:
More by ian:Thermal Tweeter networked Twitter printer @tweet_tree: Twitter controlled Christmas tree Hackable Christmas card & ornament
Add instructable to:
