loading
Step 1: what you need
skills you need:
-how to crochet, until you know how to do a triple crochet; you can learn it from: Learn To Crochet 101 by Teresa (video-tutorials): http://www.youtube.com/view_play_list?p=D949DB26ED937B07
-how to make yarn from a plastic bag; you can learn it from my first instructable, but make fringes from about 10mm: http://www.instructables.com/id/Plastic_Bag_Yarn_quotshortcutquot/
what you need:
-crochet hook number 14 or 2mm
-scissors
-plastic yarn from about 10mm width:
...-a little thin plastic bag in blue or another "butterfly" colour
...-a little bit of black or another dark colour
abbreviations: ............................................... (NL) afkortingen:
(if nothing is mentioned, you put every stitch in the following stitch off the previous row or round)
st................. stitch(es) ................................... s ........ steek/steken
ChS ........... chain stitch ............................... L ....... losse
SlSt ............ slip stitch .................................. hv ...... halve vaste
SC .............. single crochet .......................... v ........ vaste
DC .............. double crochet ........................ st ...... stokje
TC ............... triple crochet .............................d.st ... dubbel stokje
- [...] = work instructions within brackets as many times as directed.For example: [SC - 2ChSt] x 3 = SC - 2ChSt - SC - 2ChSt - SC - 2ChSt
- in chSp: {...}: put your hook in the chain space with all stitches between the following accolades for example: "in 3chSp: { 2DC - 2TC - 2DC}" means you have to make 2 double crochets AND 2 triple crochets AND 2 more double crochets ALL in the same chain-space you made by crocheting 3 chain stitches in the previous row or round
- pic = picot = make 3 chain stitches, and a slip stitch in the stitch where you started the picot from. For example: "2TC - pic - TC" means you have to make 2 triple crochets, then you start the picot by crocheting 3 chain stitches, then put your hook through the top of the last triple crochet you made, and make a slip stitch, and then make your last triple crochet at the previous row or round; so the 3 triple crochets are in one line, as if you crocheted 3TC, but with a bump.
(NL)
wat je moet kunnen:
-hoe je haakt, tot je een dubbel stokje kan maken, volgende linken kunnen het je leren: (PDF, tot een stokje), http://www.galt.co.uk/pdf/cc_guide/CC_Dutch.pdf en (vanaf halve vasten) http://www.hobbydoos.nl/haken/haaktechnieken.asp
-hoe je wol maakt van een plastieken zak; je kan het leren van mijn eerste instructable: http://www.instructables.com/id/Plastic_Bag_Yarn_quotshortcutquot/
nodig:
-haaknaald nr 14 of 2mm
-schaar
-plastiek wol van ongeveer 10mm breed
... -een klein dun zakje met blauw of een andere "vlinder" kleur
... -een beetje zwart of een andere donkere kleur
afkortingen:
(als er niets vermeld is, steek je elke steek in de volgende steek van de vorige toer of ronde)
L ....... losse
v ........ vaste
st ...... stokje
- [...] = haak de instrukties tussen de haakjes evenveel maal als er staat aangegeven.
Bijvoorbeeld: [v - 2L] x 3 = v - 2L - v - 2L - v - 2L
- in boog {...}: steek bij alle steken tussen de accolades in dezelfde boog. Bvb.: "in 3L-boog { 2st - 2d.st - 2st }" wil zeggen dat je 2 stokjes EN 2 dubbel stokjes EN nog eens 2 stokjes allemaal in dezelfde boog van 3 lossen moet steken die je de vorige toer of ronde gemaakt had
- pic = picot = haak 3 kettingsteken, en een halve vaste in de steek voor je de picot maakte. bijvoorbeeld "2st - pic - st" wil zeggen dat je eerst 2 stokjes haakt, dan 3 kettingsteken, dan je haak door het laatst gemaakte stokje steekt om je halve vaste te maken, en je voor je laatste stokje weer verder op de vorige toer of ronde haakt; zo zouden de 3 stokjes naast elkaar moeten staan, alsof je gewoon 3 stokjes haakte, maar dan met een bult.
That looks amazing. =D<br/>
That looks great, I really like the colours.
Hey thanks! And, you made me find the positive side of being ill: when you buy your medicines, they put them in a nicely coloured bag where you can make nice things with :-)
About This Instructable
4,429views
30favorites
License:
More by ShirCraftalot:How to Knot a Butterfly by Macrame knot 4 pets Butterfly, How to Crochet it from a Plastic Bag
Add instructable to:
