3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Butterfly, How to Crochet it from a Plastic Bag
Step 3Complete half a butterfly
complete half a butterfly
3) - turn - in 5chSp: { 3DC - TC - pic - 2TC - 3DC - SC } - SlSt - in 3chSp: { 2DC - 2TC - 2DC } - in last st: SlSt
3) for beginners:
(3a=turn) = so your craft is at the left, and your hook at the right
(3b=in 5chSp) = so all stitches between the following accolades must be put in the space you made with the 5 chain stitches in the previous row.
(3c=3DC) = 3 double crochets in the 5 chain space
(3d=TC) = 1 triple crochet in the same 5chSp
(3e=pic) = a picot: 3 chain stitches and a slip stitch at the top of the triple crochet you made in 2d
(3f=2TC) = 2 more triple crochets in the same 5chSp (the triple crochets and the picot from 3d to 3f should look as if you made 3 triple crochets with a bump
(3g=3DC) = 3 double crochets in the same 5chSp
(3h=SC) = a single crochet, the last stitch in that same 5 chain space
(3i=SlSt) = a slip stitch, and since nothing is mentioned, you put your hook in the stitch following the stitch you just made a stitch on; it sounds difficult, but its quite easy: just put your hook in the stitch after the 5 chain space, and make your slip stitch
(3j=in 3chSp { 2DC - 2TC - 2DC }) = the stitches between the following accolades must be put in the 3 chain space you made in the previous row, so make 2 double crochets, 2 triple crochets, and 2 more double crochets in that chain space
(3k=in last st: SlSt) = put your hook in the last stitch of the previous row, and make a slip stitch
(NL 3) - keer - in 5L-boog: { 3st - d.st. - pic - 2d.st - 3st - v } - hv - in 3L-boog: { 2st - 2d.st - 2st } - in laatste steek: hv
3) voor beginners:
(3a=keer) = draai zodanig dat je werkje links is, en je haaknaald rechts
(3b=in 5L-boog) = dus moeten alle steken tussen de volgende accolades in de boog gestoken worden, die in de vorige toer met 5 lossen is gemaakt
(3c=st) = 3 stokjes in de 5L-boog
(3d=d.st) = 1 dubbel stokje in dezelfde 5L-boog haken
(3e=pic) = haak een picot: haak dus 3 lossen, en een halve vaste op het dubbel stokje dat je in 2d haakte
(3f=2d.st) = haak nog 2 stokjes in dezelfde 5L-boog (de dubbele stokjes en de picot van 3d tot 3f zouden er moeten uitzien als 3 dubbele stokjes met een bult)
(3g=3st) = 3 stokjes in dezelfde 5L-boog
(3h=v) = een vaste, de laatste steek die je in diezelfde 5L-boog maakt
(3i=hv) = een halve vaste, en aangezien er niets vermeld is, steek je je haaknaald in de steek na de steek waar je juist een steek op maakte; het klinkt moeilijk, maar het is gemakkelijk: steek gewoon je haaknaald in de steek na de 5L-boog, en maak je halve vaste
(3j=in 3L-boog: { 2st - 2d.st - 2st }) = de steken tussen de accolades moeten in de 3L-boog van de vorige toer gestoken worden, dus maak 2 stokjes, 2dubbele stokjes, en nog eens 2 stokjes in die boog van 3 lossen
(3k=in laatste steek: hv) = steek je haaknaald in de laatste steek van de vorige toer, en haak een halve vaste.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ShirCraftalot(ShirCraftalot)
