Button Trigger for Google Assistant on the Raspberry Pi
4,006
49
Published
Introduction: Button Trigger for Google Assistant on the Raspberry Pi
About: Avid Thinker, Computer Programmer, Web evangelist, Hacking / Breaking expert, Problem Solver, Technology Obsessed, Gamer, 3D printing, Coffee lover!
On this Instructablel I will be showing you how you can add a button trigget to your Google Assistent, which is running on your Raspberry Pi.
Hope that you like it and thanks
Step 1: Get Everything Ready
For this tutorial you will need:
Step 2: Connect Everything to the Raspberry Pi
Connect the momentary switch to Ground (3rd pin from right to left on the bottom row) and to the GPIO18.
Connect the LED Light to Ground (8th pin from right to left on the bottom row) and to the GPIO23.
Step 3: Download Our Dependencies
Get intot he Raspberry Pi with Raspbian on it and open up the Command Prompt.
Type in "source env/bin/activate" and then press "Enter"
Once we are inside our enviroment, type "pip install RPi.GPIO" and press "Enter"
Step 4: Edit the Googlesamples File
On the Command Prompt, type in "geany env/lib/python3.4/site-packages/googlesamples/assistant/__main__.py"
Once the Geany editor opens, scroll down after the last "import" and create a new line.
Type in ""import RPi.GPIO as GPIO"
Scroll down to the Line 37 and type in "GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN pull_up_down=GPIO.PUD_UP)
GPIO.setup(23, GPIO.OUT)"
Scroll all the way down to the Line 196.
Comment out the code in the Line 196 by adding an "#" to the start of the code.
NOTE: Remember that Python works by tabs, but the file is indented by spaces, so keep in mind, 1 Tab = 4 Spaces
Create a new line over the code you just commented out and type in "input_state = GPIO.input(18)
if input_state == True
GPIO.output(23,False)
continue
else:
GPIO.output(23,True)
pass"
Save the file and close it.
Step 5: Enjoy Your Button Trigger
Go back to the Comand Prompt.
Type in "python -m googlesamples.assistant" and press "Enter"
You can now press your button and talk to your your Google Assistant in a Raspberry Pi.
And that's it, now you can wake up your Google Assistant in the tap of a button, literally.
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    I have problem, when i write this code i have error:
    pi@raspberrypi:~ $ source env/bin/activate
    (env) pi@raspberrypi:~ $ python -m googlesamples.assistant
    Traceback (most recent call last):
    File "/usr/lib/python3.4/runpy.py", line 151, in _run_module_as_main
    mod_name, mod_spec, code = _get_module_details(mod_name)
    File "/usr/lib/python3.4/runpy.py", line 118, in _get_module_details
    return _get_module_details(pkg_main_name)
    File "/usr/lib/python3.4/runpy.py", line 126, in _get_module_details
    code = loader.get_code(mod_name)
    File "<frozen importlib._bootstrap>", line 1572, in get_code
    File "<frozen importlib._bootstrap>", line 1532, in source_to_code
    File "<frozen importlib._bootstrap>", line 321, in _call_with_frames_removed
    File "/home/pi/env/lib/python3.4/site-packages/googlesamples/assistant/__main__.py", line 322
    IndentationError: expected an indented block
