Buying a boat online: Adventures of Lil Putt Restoration
 by station420
Featured
Step 1: Lesson 1: Too Good to be True?
A friend of mine found this boat online for $1500, so we went to have a look.  Initially, it was going to be a flip, but upon laying eyes on her, all entrepreneurial ideas went out the window.  My girlfriend and I fell in love with her and after some discussion about her present condition, purchased her on the spot for $1200.   The previous owner, Frank, stated that the 'Vessel ran great before he replaced the injectors'.  At the time, reality was no where to be found as our minds were envisioning hours of pleasure cruising up and down the Gulf Islands.  In hindsight, the appropriate question to ask should have been, "if the engine ran so great, why replace the injectors?"  But alas this was not to be, so we gave him a wad of cash,  hooked her up to the truck, and took her to her new home.  Remember, always find out all you can about the boat BEFORE you buy it!!
The vessel's name is 'Lil Putt' and was built on Vancouver Island.  There were 5 similar vessels built but I have only managed to track down 2 that are still operational. She is 14ft long, has a Volvo Penta MD4b Diesel Engine, and was built in the early 60's across from Mill Bay in a fellow's garage.
Step 2: Lesson 2: Diagnosing the isses... the fun begins
When we returned home, we launched her in the water, got out the tools, and began the battle.  After hooking up a battery, putting some diesel in the tank, and checking the oil, it was go time... or not.  While we knew she wasn't operating properly, our first thoughts were she just needed a little TLC and we'd be off and running... putting rather.  While Frank couldn't say exactly what the issue was, he was kind enough to leave sticky notes all over the vessel to identify fuel shut off valves, master switches, and odds and ends that might come in useful... if she ever started.
She sounded as if she just might turn over, laboured as it was, hope was in sight... until she preasure locked... or so we thought.  Hand cranking it seemed to unlock the little Volvo and we employed this method multiple times until the hand crank joint snapped off.  We still had the battery so for the next two days we tweaked everything from the timing of the fuel pump to the alternator but it was a no go.  She just wouldn't start, and then she locked up completely.
Faced with the reality of this situation (ie.  We wouldn't be sipping cocktails Putting through the Gulf Islands anytime soon), it was time to pull out the Volvo and identify the issues... we still had no idea what was wrong.
Step 3: Lesson 3: Have lots of friends
When buying a used boat, it is important to have lots of friends to help with towing, lifting, troubleshooting, and sharing a case of Lucky Beer when you just can't figure out what the hell is wrong.
On a sunny spring afternoon, we finally lifted all 400 pounds of the 'little' Volvo Penta onto the dock and loaded her up.  Again, the key point in this lesson is friends and beer... (lots of both).
Step 4: Lesson 4: Be prepared to be frustrated
Step 5: Lesson 5: Carefully Examine the Vessel Before Operating
We were now ready to fire her up... but we couldn't seem to find neutral on the stick. While playing around with the 'gear stick', another friend, standing behind the vessel on the dock, and having the sun light shine down at just the right angle, discovered that the blades of the prop rotate as we move the stick up and down. Eureka! We have a feathering prop, what luck!
VOLVO Penta MD5 Marine Diesel
Side note on the feathering prop:  One can come into the marina at full speed, drop the feathering prop into reverse, spin Lil Putt on a dime and dock her like Capain Ron.  For more information on this very appropriate and acceptable manouver, please see below!
Step 6: Lesson 6: You don't need alot of money
Being on a shoe string budget, it was time to clean her up and add a few gadgets:
- Old Color Depth Sounder (found at the local dump)
- Old VHF radio and antenna (traded to Grant for other old electrical equipment)
- Salvaged Fenders and life jackets (floated in on the tide)
- Flood lights, electrical panel, wiring bits and pieces (discount bin at the local Marine supply store)
- Paint (some donated, others not so cheap)
- Battery Charging regulator (not so cheap at all, but somewhat mission critical)
- Salvaged paddles (came in handy too many times before battery charger installed)
- Salvaged Captain's Chair
Here's a few links to some boat wiring diagram:
http://forums.iboats.com/showthread.php?t=186986&page=1
http://www.boatdesign.net/forums/attachments/onboard-electronics-controls/32302d1244484193-simple-wiring-diagram-small-craft-electrical1.jpg
With a fresh coat of paint and all electronics installed it was time for Sea Trials:
Step 7: Lesson 7: Enjoying the finished project
After all the effort, Lil Putt was a sucess!  Since the restoration, she has been put to work as a towing vessel, salvage vessel, delivery vessel, and pleasure vessel.
While the diesel tank is only 70 litres, I can honestly say that this is enough to run her for weeks.  We had a great summer Putting all up and down the Islands and in hind sight couldn't have had a better project.  Of course non of this would have been possible if it wasn't for Dan, Hal, Mr. Futs, and countless others who contributed knowledge, parts, and labour along the way.  THANKS!
As for spring 2011, a new list of repairs grows in the back of my mind,
- Replace running light that got ripped off towing a 20 ton sailboat
- Repair hull scuffs acquired practising Captain Ron Manouvers
- Install air intake pipe through roof to reduce noise
- New Casing gasket to prevent diesel fumes from filling cabin
- Install towing cleat so Dan doesn't have to sweat so much
- New bottom paint
- Convert Diesel to Bio Diesel (idea from Tbonestone  instructables member)
Until the spring... and perhaps another project vessel.
1-40 of 55Next »
stormy0314 says: Feb 26, 2011. 11:38 AM
I love this, but... It is a wonder you were able to get any help at all serving that kind of beer. Shudder, shudder.
This is just the type of boat I would like to have. What was your total cost to get her in the water? What did you have to do to the engine? Really nice boat. Thanks for the 'ible.
abadfart in reply to stormy0314Feb 26, 2011. 9:44 PM
i don't know if its that bad i get bought off with pbr for everything from engine work to installing radio gear
SIRJAMES09 in reply to abadfartJun 26, 2011. 6:58 PM
PBR?!?!
I didn't know they still made that stuff!! I used to use that to bribe the kids with! LOL got a lot of work done that way. Personally, I think PBR is some nasty stuff, but if you're happy with it, then so be it.
I love that boat BTW, just the kind I would like to have. 8=D
stormy0314 in reply to SIRJAMES09Jun 29, 2011. 3:13 PM
PBR gave me my worst hangovers in all my years. And, station420 being from Canada has some of the best beers in the world close at hand.
station420 (author) in reply to stormy0314Feb 26, 2011. 11:54 AM
Not sure of the exact total, perhaps $1600 including paint, electrical wiring components, and the motor. Plus transportation costs to get her on the ferry ($100). Basically we took a whole bunch of parts from the 2nd engine and installed them on the first, mainly all the gears and the fuel pump and a couple other parts that we in poor condition.
stormy0314 in reply to station420Feb 28, 2011. 2:12 PM
This is a really nice boat. I have built and repaired a total of three boats from 12 to 20 feet. I think a little light weight portable cabin end to catch heat from an aftermarket heater would make this boat just about ideal. You could fish and travel in comfort in winter. Are you from Canada?
SIRJAMES09 says: Jun 26, 2011. 7:19 PM
sounds like somebody had a lot of fun....BEFORE it made it to the water. LOL
Wish I was so lucky to get a boat like that....but I'd want one that's a wee bit bigger so I had some place to live besides this suburban apartment....I hate city life.
I wish you & the family the best with your new toy! LOL
dla888 says: May 16, 2011. 7:39 PM
A color depth sounder from the dump???!!! I need to start visiting my local dump!
bpfh in reply to dla888Jun 23, 2011. 2:15 PM
My thoughts exactly :)
nasd9 says: May 10, 2011. 12:16 PM
I have an rc boat that kinda looks like that
JCoffey says: May 6, 2011. 7:59 AM
May I ask what style of boat thats called? I would LOVE to have a small vessel just like that one!
station420 (author) in reply to JCoffeyMay 9, 2011. 12:49 AM
Not too sure! Haven't seen any others like it.
cbjjbc says: Apr 23, 2011. 8:09 PM
Your instructable is the only one I've commented on. Some one's prayers where
answered. Good luck.
juicymoose says: Apr 15, 2011. 3:10 AM
wish i had one like it but im 3.5 hours away from the nearest lake or the sea grrrrrr. anyway fab boat
SpecializedRabbit says: Feb 25, 2011. 3:02 PM
I love your boat! Whats the cruise speed?
station420 (author) in reply to SpecializedRabbitFeb 25, 2011. 3:10 PM
about 6 knots with a clean bottom
Mr. Potato Head in reply to station420Mar 8, 2011. 6:37 PM
I always make a point of keeping my bottom clean...
ilpug in reply to Mr. Potato HeadMar 17, 2011. 10:01 AM
good man.
playfulplans says: Mar 9, 2011. 5:00 AM
One of my favorite Instructibles.
I'd like to build a battery-op toy version for my website...
station420 (author) in reply to playfulplansMar 9, 2011. 10:50 AM
let me know when you do!
SinAmos says: Mar 7, 2011. 10:58 PM
'Vessel ran great before he replaced the injectors' - so, what was the problem, if there was one?
station420 (author) in reply to SinAmosMar 8, 2011. 11:53 PM
Some of the teeth on the gears had broken off and locked the gears so she wouldn't turn.
SinAmos in reply to station420Mar 9, 2011. 12:06 AM
Ty for answering and sharing. Take care.
lucek says: Mar 5, 2011. 9:41 AM
"Convert Diesel to Bio Diesel (idea from Tbonestone instructables member)"
I know you probably already know this but be ready to replace or clean everything that can get clogged. An old fuel tank will have a ton of crud on it. The kind of crud that biodiesel is a perfect solvent for.
That said it's a nice little vessel. Hope she lasts you many a good year.
kought says: Mar 3, 2011. 9:57 AM
Awesome project, those little old diesels will literally go forever. Most diesels will, especially a Volvo. Running biodiesel is probably the best thing you can do for it too, it's basically like 2-stroke mix, the bio is super lubricating (compared to diesel) and will make your cylinders and pistons last for forever x2. Sweet boat too, I dig it.
sodiumcanine says: Feb 27, 2011. 2:26 PM
Hard to find small boats with Diesels, The MD5 is a
Tough little Diesel.
Working with a Charity I have come across a few donations that where.....Donated.... Now I am working on Selling
2 Lifeboats for them, With an Instructable on how (or not) to
do it
station420 (author) in reply to sodiumcanineFeb 27, 2011. 2:45 PM
cool lifeboats, where are they at and how much?
sodiumcanine in reply to station420Feb 28, 2011. 8:00 PM
They are Lying Wilmington,Cali
30 ft Loa 10ft Beam
7500lbs Left one, 2 Cyl Lister Aircooled Diesel
6000lbs Right one, Oars, and Manual push pull
Heavy Fiberglass, Sink-resistant,Stable.
Could be Converted into Houseboat,Sailboat,HotTub,Pool,Planter Or?................
Reasonable Offer.
Historical Note: Pembina WasOllie North's Iran Contra Ship.
TX, MikeMcV
mattbesquare says: Feb 27, 2011. 6:55 PM
I am sitting here in my living room about 9:00 at night yelling "oooh" "OUCH" "AAHHH" as I click through each picture. I have so many painful lessons learned this way it is hard to count.
I have some cold beverages over here if you want to help me pull a block out of an old VW.....it shouldn't take long at all. ;-)
station420 (author) in reply to mattbesquareFeb 27, 2011. 9:02 PM
I'll be over in 5
lovemachinesix in reply to station420Feb 28, 2011. 3:35 PM
Lol.
certos says: Feb 28, 2011. 12:47 PM
man I would LOVE a project like this. I wish I could find a boat in Ontario to work on.
porcupinemamma says: Feb 27, 2011. 8:49 PM
Perhaps we should ask the company who made the blue bumper to take a look at your rockin' Instructable and hope that they will donate a set of brand new ones for the upcoming season. West Marine also has contests :0)
station420 (author) in reply to porcupinemammaFeb 27, 2011. 9:03 PM
Which company are you refering too?
porcupinemamma in reply to station420Feb 28, 2011. 4:56 AM
lol ;0) The company who made the blue bumpers on your cool boat. My husband has blue bumpers for his boat. They look quite spiffy ;0)
bpfh says: Feb 28, 2011. 1:43 AM
So what was the main problem with the engine in the end (or did I miss somthing?)
If you are concerned with fuel economy, you may be interested in attempting to add an air swirler (like a fan but flxed so the air is whirled around it) just before the air intake into the injection chamber:
Modern diesels are designed so this happens as standard (it breaks up the injected diesel spray into smaller droplets and you get more bang for your buck).
Biodiesel is a good idea, as mentionned above, but you could also add cooking oil to the fuel (just filter any food lumps out of it!!). You could probably run it on pure cooking oil (I love the older diesel engines, you can do a lot of DIY with them!), but you may need to add a tad of white spirit to fluidify the oil, but if you are not using a lot of fuel, mix with diesel and you are good to go...
Cheers!
Foehammer358 says: Feb 27, 2011. 9:41 PM
awesome.just awesome.
That little thing can tow a 20 ton sailboat?
where did you find the ad for the sale?
mcgary911 says: Feb 27, 2011. 8:31 AM
I think you could have titled this one "How NOT to go about Buying a Boat Online".
Ideally, you'd want to have the vessel surveyed by a qualified marine surveyor. In the US, the 2 main surveyor societies are SAMS and NAMS.
http://www.marinesurvey.org/
http://namsglobal.org/
If you're looking to get your boat insured at a later date, the insurer will likely insist the vessel is surveyed.
Even if you don't go the survey route, insist on a sea trial, or at least make sure you see\hear the motor run. IF you know you're buying a non-runner, guess this wouldn't matter as much. Also test all the systems and controls. Check for rot and water damage as well. You can find rot by lightly tapping on the hull with a non marring hammer.
All of these things will let you know whether you're buying a runner, or a project that may be beyond your financial or mechanical capabilities.
Thankfully, you seem to be pretty handy, and had the support of some helpful friends. Most importantly, you're now enjoying your boat. Heck, it even looked like you and your friends had tons of fun getting her sea worthy.
I'd suggest not skimping on the safety stuff. If you broke a running light, fix it asap. It's a quick, easy and essential fix. Make sure you carry things like flares and the proper lines. Find some new lifejackets on sale. Something that floated in may not be the best route there.
You didn't mention it, but make sure you have a working bilge pump. Your worst day boating will be showing up at the dock on a nice day only to find your Putt on the bottom. Another thing that can fail on an older boat, is the stuffing box. New packing is pretty cheap (it's basically waxy rope), and you can repack your stuffing box in less than an hour. Great insurance.
Make sure your sacrificial anodes are in good order (zinc or aluminum, depending on salt or fresh water). They'll save the metal bits all over your boat.
Wow. Guess this is a long reply, but just want to share a few thing I've learned during years of boating.
That thing sips diesel, you'll really appreciate that with the price of fuel these days.
Enjoy your boat.......sounds like you have that part nailed already. ;)
Calorie in reply to mcgary911Feb 27, 2011. 4:50 PM
agreed. Instructable projects tend to be a bit more on the "flight of fantasy" side. I was horrified when they stated the life jackets used were found floating in on the tide. That water is cold and you wouldn't last long treading water.
menahunie says: Feb 27, 2011. 3:26 PM
Cool; but if your going to keep the boat and it looks like it I would consider looking around for an outboard to hang off the back for backup engine; just in case..
1-40 of 55Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
