Buzz Bee Big Blast Modification
7,318
Published
Introduction: Buzz Bee Big Blast Modification
Today, we'll be modding a Buzz Bee Big Blast, commonly referred to as a BBBB.
Materials:
A Buzz Bee Big Blast
At most a foot of 1/2 in. cpvc
The barrel extension from a Nerf Longsot front gun
Hot Glue gun
Hot Glue
Electrical Tape
Tools:
Hack/Band saw
Hot Glue gun(listed above)
Step 1: Disassembly/Minimization
On the front of the BBBB, there will be an orange ring connecting the two halves together. Pry it off by any means necessary. Once you get that off you can unscrew the gun. Take out the internals. Now this step may be a little confusing. Cut where I did. Actually, cut a little before where I did, then sand it down so it looks like the pictures.
Step 2: New Barrel
Cut the stock black barrel don so there is about a centimeter left. Then, sand it down on the outside so the orange barrel extension fits over snugly but not to snug or you could crack it. If it's too lose for you, stick it on and glue or tape it but, that would make this mod semi-irreversible. Cut your orange barrel extension to about 5 inches and stick it on. Now, get your cpvc and cut it to your desired barrel length 9-10 inches works well. Wrap your electrical tape around the end and where the barrel comes up to for an airtight seal.
Step 3: Plugging the Pump
Get your hot glue gun ready and fill in the hole on the pump head like the picture. Now you can only pump it 15 times or YOUR TANK WILL EXPLODE!!!!!!!! You plugged the over-pressure valve. I recommend 10 pumps.
Step 4: Re-assembly
Now put it back together and shoot some fools with it!
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    8 Comments
    What does blocking the pump do? does it make it faster to pump up to fire or has no other result than easier to break the gun?
    the thing you plug is called like a release valve or something liek that, and after a certain amount of pressure is in the tank the release valve will kick in so it cant get any more pressure, plugging it allows you to get more pressure, giving the gun more power. ( but it can explode or crack if you plug the valve and pump it too much)
    oh i see, fair enough. I'v never owned or really even held a nerf gun before so i odnt know what the air pressure tank is like but would the gun have even more firing force if you added rubber bands around the tank or would that be water guns only?
    well, i never heard of anybody doing that, i dont see what it would do, but it might work.
    that is cool but mine is better this beast smokes from the barrel from only 3 pumps i promise u all it does ill try to get pics and i had no idea what the heck i was doing that was my first mod
    HOLY %*#! That thing looks SO different from mine!
    Longshot frontgun barrel Its the barrel from the pistol on the front of the longshot.
