What that means for me is that I'm the one left to do all the sewing and Halloween costume-making. This arrangement works out well--she likes to cook, and I like to make stuff and eat well. It's a happy marriage.
This year (2008) my kids wanted to be Buzz Lightyear and Sheriff Woody. This instructable focuses on the Buzz costume because it required a more unique, creative approach.
Remove these ads by
Signing UpStep 1Chest piece structure
I cut, shaped and sculpted as I went.
Too bad we didnt win our costume contest, idk why!
I used a cardborad barrel. You can usually pick them up for free from hardware stores or warehouses. I am very happy with the result. I built a Buzz 10 years ago, after seeing this instructable I decided to re vamp mine.
Make sure the firs hole is cut around the needle hole where you inflate the ball
The top circular piece of cardboard strengthened everything quite a bit. If the bottom is flimsy, you could add a ring of cardboard to the inside as well (as long as you can still slip the entire thing over yourself to put it on).
I wouldn't use duct tape to hold everything together. Certain parts will just work better and end up stronger if you use hot glue (I can't give specifics, because I'm not sure of what you've got so far.)
I agree, the top circular piece added a lot of structural integrity, but I didn't do anything about the bottom. It's not going to be a huge problem, as it isn't SUPER flimsy, and if I add another ring I won't fit inside anymore haha. I was using spray paint for the white, except it showed too much of the masking tape edges, so I went on to using acrylic instead. I haven't finished yet, but I'll post pics as soon as I'm done. Surprisingly, I didn't use a lot of hot glue, just a bit here and there, but I usually use quite a bit in other projects. I just used cardboard and a lot of masking tape, and some duct tape and hot glue. Here are some pics:
To cover up the tape and smooth things out on mine, I first painted it with a couple of really heavy coats of latex house paint. (I notice that I failed to mention this in my instructions...) THEN I spray painted it white, and added details with acrylic craft paints. Probably too late to mention that now. Oh well. Anyhow, yours looks great. You definitely need a bright red "laser" on your arm... you're going to make arm and leg pieces, right?
Be sure to post some finished pictures.
Would you know what I would need to measure for it? (Ex: The size of my neck,etc...)
It may take a little trial and error on your part, but you can do it!
You might have to make one, make changes as needed, and then make another and another till you get one you like. That's how I do it. Good luck!
I would really like to make my own! :3
(I did start including PDF patterns with my more recent sewing projects though, if you're interested.)
Much much better than store-bought :)
Much better quality as well, not that creepy polyester stuff
