Introduction: BuzzBee Rangemaster Mod
Picture of BuzzBee Rangemaster Mod
I wanted a WW2 Carbine/Rifle that i could use on Apoc LARP.
There are non to buy that i liked, so i created one.
So i opened the Rangemaster i had purchased and the internals where ok.
The Rapidstrike on top is only for size comparison.
First i thought a singlefire would be ok, but later i discovered the endles posibilitys of RSCB and Inlineclips.
Due to the space shortage in the actual riflestock i decided for a inline clip.
The clip is about 2 1/2 elites long an d takes 2 Elites or 6 shortened darts.
The barrel is about 22cm long and from 17/32 brass.
Step 1:
Picture of
The Stock was sitting in my basement for years and i tried the rangemaster intenals and they fittet in pretty good.
Step 2:
Picture of
The pumphandle needet to be placed closer to the handle, so i cut it away and bend it to match my stock.
Step 3:
Picture of
i needet a trigger and something to hold the release, so i build it out of plastic sheets.
Step 4:
Picture of
Next was the visor and the cover for the breach, so i built a holder für the original visor out of pvc card.
Step 5:
Picture of
The brass barrel was a bit thin and brass is hard to paint durable, so i made a cover from pvc.
i also build the second part of the visor.
Step 6:
Picture of
Last step was a release with some springs.
The actual release is on the left side, the right side is open.
So if you unlock the system and pump, the valve can move free on the right side.
As soon as you lock the system and close the breach the valve moves to the left side and the release can press the valve.
Step 7:
Picture of
This is how it looks now.
Ranges are betwen 20-25m.
You could fit a rangemaster pump and some brass barrels in allmost every ww2 stock.
Garant M1, Nosin Nagant, Lee Enfield, what ever...
Thanks for watching!
Here is the video of it working.
And how the trigger works.
https://www.youtube.com/watch?v=WvM7KzNBNrQ
WildSau (author)2015-03-20
You were right, i fliped it horizontally.
Corrected.
No, we don't need orange barrels in germany.
dj_nme (author)2015-03-20
It seems like one of your "finished" pictures is flipped horizontally, or did you somehow change the Rangmaster innards to be left-handed?
The result is amazing, but you might want to put an orange barrel tip on if it's going anywhere outside.
I will try one as soon as possible.
tomatoskins (author)2015-03-20
This turned out looking great! I'd love to see a video of how well it works.
About This Instructable
2,984views
27favorites
License:
More by WildSau:BuzzBee Rangemaster Mod
Add instructable to:
