Introduction: Buzzer Throwie
Picture of Buzzer Throwie
Have you ever wanted to annoy someone? I mean REALLY annoy someone, or even a whole bunch of people? Imagine, if you will, being forced to sit through another tedious class of Religious Studies or attending one of those departmental meetings which go on and on and on...
Wouldn't things go so much more swimmingly if there was an unending torrent of high-pitched beep going on the background? Sure, your predicament may be boring and now even extremely annoying, but knowing that you're secretly the cause of it all will give you something to smile about on the inside. Oh yes!
This super-easy instructable can be built by people with monkey hands, like myself, and with very little electrical knowledge and no soldering skills whatsoever to provide literally hours of annoyment.
Bastard son of the LED throwie, the Buzzer Throwie is basically a loud buzzer connected to a small button battery which will power the device for over 8 hours and being connected to a powerful rare-earth magnet will allow you to secret the device under desks, on metal ceiling pillars. Pretty much in any inaccessible magnetic place you can find in a modern lecture theatre or classroom.
Ok, here's a list of parts you will be needing. They are all available from the web. I use dealextreme for much of it, since they are cheap and I like them, but ebay does just fine as well. There are no sophisticated parts in this project, it's all rather ghetto.
Parts:
1 x 9mm rare-earth magnet. Very small and very powerful. Any size will do, but 9mm seems to be powerful enough to stick this throwie.
1 x 3v button cell battery. You can use 2 x thinner 1.5v ones, but that's more parts to be assembling and add unnecessary complexity. Remember, this is an instructable for my cack-handed brethren.
1 x 5v piezo-electric buzzer. I got mine from ebay. They run from 1.5v to 5v. It's louder with more volts, so the closer you get to 5v then the more annoying it will be.
1 x roll of Scotch tape, or similar. I just had Scotch tape to hand, and you don't even need scissors to cut it, so I just used that. Any other tape would work just fine though.
Now, to assembling this thing
Step 1: Gentlemen, Prepare Your Buzzers!
Picture of Gentlemen, Prepare Your Buzzers!
The first step is to prepare your buzzer. Note that the buzzer I have used it polarity dependent. That means you have to make sure that you connect the positive end of your battery to the positive end of your buzzer (the red wire).
We will be removing the wires from the buzzer and the shrink-wrap contact sleeves. So just snip the wires either with scissors, some pliers (the best way) or your teeth (not the best way as you might end up eating the buzzer. Do not do this as you'll be needing it later on. And it might kill you).
Make a note of which end is which, but if you don't then don't worry as I didn't and I just connected it up to the battery until it worked. It didn't seem to do it any harm.
Step 2: Assemble It
Picture of Assemble It
The next part is to assemble it.
1. Place the buzzer at the bottom, upside down.
2. Place the battery between the buzzer contacts and squeeze together until it buzzes. Annoyingly. Very annoyingly in fact after a few minutes.
3. Attach the battery carefully to the top. If you just drop it then the battery can crack, as they're fragile little things.
4. Wrap up the whole thing in your tape, making sure that the contacts are still making a good connection with your battery.
5. To stop the buzzer squealing at you, you can temporarily tape the end of it up and remove it when it comes to deploy time.
Step 3: Deploy
Now comes the time to deploy this baby. Find somewhere really annoying to throw it. Make sure you remove any tape from the end of the buzzer you have previously placed. The nature of the sound coming from the buzzer makes it infuriatingly hard to locate and even more difficult to ignore.
We have metal roof beams in our office and I have successfully deployed it here. I have 20 co-workers who agree that it's not a good thing to be working beside for 8 hours. The little AG13 battery lasts in excess of 8 hours at annoying volume levels and decays steadily after this.
To be environmentally friendly, please make sure that you put this in a hidden, but accessible place so you can retrieve it later. Afterall, there's about 50p worth of parts in your device and you can use it again and again! Don't foul up your nice environment with nasty battery chemicals. You'll end up eating or drinking them further down the line anyways.
Step 4: Other Thoughts...
Picture of Other Thoughts...
I also bought a bundle of Melody Chips, which are simple, three pin affairs which can be connected up to your buzzer. The ones I bought (for about 80p each) had some bad rendition of some lesser-known and even less recognisable Disney tune. They can easily be soldered to your buzzer to let it pump out some awesome melodic mayhem to your co-workers. Sadly, there's a bit of voltage drop causing the buzzer to be a little quieter, so this would work better with some added amplification. I may document this in future instructables, if I ever develop enough skills with these wretched hands of mine to solder these itty-bitty parts together without melting holes in my carpet (again..).
Well, that's it for my first instructable. It's pretty dumb and lacking in artistic flair and skill, but I've been visiting this site for ages now and haven't contributed anything yet, so I thought that something is better than nothing.
Let's hope I don't die (at the hands of my co-workers most likely) before my next one as this would be a pretty dismal way to be remembered.
Lowney (author)2009-09-29
I finally have the solution to it all!
mikee963 (author)2009-09-23
where can you find some buzzers without spending some money?
thekanester (author)mikee9632009-09-23
It probably sounds a little obvious, but harvesting from old electronics is a good way. The perfect source would be from one of those greetings cards that play annoying messages, or perhaps an old/dead mobile phone. I'm not sure if a regular small speaker would work, or if you have to use a piezo buzzer. Perhaps someone with more electical savvy could be a little more specific than me! If you're in the UK then p.m. me and I'll send you one on.
Zem (author)2009-08-14
Where did you get the chips from?
thekanester (author)Zem2009-08-14
Hi Zem
Got them from rapidonline in the UK. Here's the linky:
http://www.rapidonline.com/Electronic-Components/Integrated-Circuits/Timers-Signal-Gens./Melody-generator-IC/34481/kw/melody
If you're based in the UK, send me a p.m. and I'll forward one to you.
Zem (author)thekanester2009-08-14
Thanks! I'm in the US, but thank you for your offer!
xproplayer (author)2008-10-09
could you add a link to a website that sells them all the time for cheap
thekanester (author)xproplayer2008-10-10
I assume I'm allowed to mention websites, but perhaps the mods can tell me if this is not the case. It was back in March that I ordered, so I had to dig around a little find the links. The Melody Generators, I got from www.rapidonline.com, in the UK. The part number is 82-0044. They cost about 30p. The buzzers were an ebay job, but you can get them from rapidonline as well. They're service is fantastic and they deliver next day pretty much. You could use their 3v buzzer, p/n 35-3616. They cost 50p. The batteries and magnets were all bought from www.dealextreme.com. Happy building!
You're allowed to mention websites as long as you are not advertising, nor spamming.
imakethings (author)2009-01-16
how could u get very loud noise from this buzzer? what is the max voltage this buzzer survives?
Wesley666 (author)imakethings2009-01-29
It does not have to be loud. If it is quiet people my think their own head is ringing, plus if its loud they will probably find it easier. It is just loud enough to hear which makes it very effective.
thekanester (author)imakethings2009-01-16
It's 5v, I think. The buzzer isn't amazingly loud, not like some of the sound grenades featured on this site. It's more persistent and annoying. I can hear it all over my 3-bed semi house, if I have it in any of the rooms. It's that annoying.
let_it_out_org (author)2008-12-30
hello! i've mentioned your instructable here:
12 Second "Soundie"
thanks for the inspiration!
Wow - I've actually inspired someone! Who knew! Your device has proper electrical components, with soldering, and knowledge and skill and everything, though, so I bow to your electrical supremacy! It's nice what you've done with your project. I'd love to have the skills to recreate it. Well done, and thanks for linking me in. It's an honour.
dsman195276 (author)2008-09-02
try adding a motion sensor to it some how so it only goes off when you throw it. good job :-)
raykholo (author)dsman1952762008-12-08
maybe that and a wireless on/off if it can be a bit bigger
i make shooting things (author)2008-09-02
its nice to see originality great job
About This Instructable
7,890views
27favorites
License:
More by thekanester:Making Gold & Silver Leaf ChocolatesBuzzer Throwie
Add instructable to:
