Bicycle Survival Kit ! by =SMART=
Contest Winner
This is a bike survival kit that I think every cyclist should own and take with them when they bike.
The Bike survival kit contains a selection of survival items that will help you survive any situation..
Essential numbers card:
If you are lost or hurt and need some help and don't have a mobile available you can refer to your number card (if you are really good at remembering numbers you don't need this)
Small coins and a note:
The small coins can be used in a pay-phone if a mobile is unavailable, the larger note can be used to buy water/ snacks/ taxi home or anything else you need
Mini first aid kit:
The kit contains some plasters and some tissue, if you have one you should also include an antiseptic wipe, this kit can be used to patch up any cuts or grazes you may encounter.
Puncture repair kit:
Probably the most important part of the kit. The puncture kit contains a small section of sandpaper , a Rubber adhesive solution , q-tips and various sized inner tube patches.
Key holder:
This key holder can be cut to accommodate any type of key and any size, you could use it to store a house key/ bike lock key/ shed key / locker key.... any key basically , you can also store multiple keys.
I have taken an abnormal amount of photos for this instructable so if you get lost just look at the pics :D
Enjoy!
Step 1: What you will need
Below is a picture of the materials and items i used, i also used some things not in the picture so i have made a list.
1 Altoids tin (minus the contents :D)
Puncture Repair Kit
Rubber soloution
Small section of fine sandpaper
Inner tube Patches
1 Q-tip
1 Small tissue
3 Paper clips
Section of card which is larger than tin
Some foam board
Pencil + Sharpie
Money
2 Coins
1 Note
3 Plasters
Antiseptic wipe (optional)
Adhesive (either super glue or a glue gun)
1 Key
Tiny piece of Blue tack
X-acto knife / Sissors
Its not actually as much as it seems :D
Step 2: Essential Numbers Card
In the unfortunate situation of your mobile running out of battery or credit you may be forced to use a pay phone booth, if you cant access the contacts on your phone will you be able to remember the essential numbers?
Steps
1 - First take your card and cut it into a rough rectangle which is slightly bigger than the Altoids tin
2 - Place the tin on the card and using a pencil lightly trace round the base of the tin
3 - Then using scissors or a craft knife cut along the outline and remove any excess card
4 - You may need to trim the edges of your card to make it fit into the tin lid
5 - Once your card fits the lid you can use glue to stick it down, super glue or a glue gun work well.
6 - Now the card is in place open your contacts list and write down the most important numbers which you would call in an emergency. (not 911 / 999 because if you cant remember that you shouldn't be on a bike at all.....)
Have a look at the picture for an example (I have blacked out the numbers on computer)
I have included my home phone number, both parents mobiles and my brothers (absolute last-resort)
Step 3: Key Holder
The Key holder is used to safely store a key where it cannot fall out, get lost or rattle around.
Steps
1 - Place your key on top of the foam board and trace around it with a pencil
2 - Now using an X-acto knife cut out the outline, you may want to cut slightly inside the outline to ensure your key has a snug fit and wont fall out
3 - Trim the piece of foam containing your key so that it fits nicley at the bottom of your altoids tin
Look at the last pic to see it in action!
Step 4: Puncture Repair Kit
When going out on a bike ride a puncture repair kit is an absolute must! punctures can strike anytime anywhere and to anyone! so be prepared!! :D
Steps
1 - Decide how many patches you want and what size combinations you want
2 - I used a small strip of paper to keep all the small pieces together (optional)
3 - Put the kit into the altoids tin, use a small piece of bluetack to keep rubber solution in place.
Step 5: Medical Kit
Now this medical kit wont perform heart surgery but it will help you with small cuts and grazes.
I have included three small plasters and a small tissue in my medical kit, if you have an antiseptic wipe handy it would be a good idea to include that too.
Steps
1 - Using scissors cut your tissue into a small rectangle so you can fit it in the tin
2 - Then use 2 paper clips to hold the tissue together
3 - Place the tissue and the three plasters in your altoids tin.
Step 6: Money Holder
If you are out and about on your bike and your mobile phone runs out of battery or credit than you will have to use a pay phone, so this part of the kit lets you keep coins some where they will not get lost or rattle about allowing you to contact whoever you need.
Steps
1 - Using a small section of foam board and some scissors cut the foam so that it fits in one end of the altoids case.
2 - Place your two coins on the foam and trace round them with your pencil
3 - Using an X-acto knife cut along the pencil line and remove the excess foam
4 - Check the coins fit
5 - Using scissors cut out a piece of the thin card and card to the back of the foam , this will stop the coins falling through
6 - For The note simply fold it up and paper clip
7 - Put the note in first and then the coin holder to clamp down the rest of the contents.
Step 7: Decorating the Tin
I didn't want t leave my bike kit as an Altoids tin because i have lots lying around and i didn't want to loose it so i quickly created a small logo and printed it off along with the instructables robot.
Unfortunately i didn't have any color ink left so i had to resort to old school coloring pencils :D
Before i stuck the images on i used some white electrical tape to mask the writing on the tin.
1-40 of 182Next »
totos says: May 2, 2009. 10:50 AM
I couldn't find altoids in russia no matter how hard i search. Just wanted to ask: what dimensions do the tins have?
letstormdufield says: Oct 13, 2012. 10:04 AM
95 mm wide, 60 mm long, 20 mm tall
dollardude says: Jul 24, 2009. 4:44 PM
i used a maths kit tin..
ERCCRE123 says: Jan 24, 2009. 4:14 PM
"not 911 / 999 because if you cant remember that you shouldn't be on a bike at all...." LOL
=SMART= (author) says: Mar 26, 2009. 4:29 PM
Hahaha!
bobt4 says: Dec 2, 2009. 4:54 PM
 i dont get it whats 911/999
=SMART= (author) says: Dec 3, 2009. 9:38 AM
emergency phone numbers
king kolton9 says: Sep 9, 2010. 11:08 AM
whats 999 i know 911 is the police
sharlston says: Sep 26, 2010. 1:45 AM
999 is the emergency services in england
cheesepuff04 says: Jun 17, 2011. 3:13 PM
it 000 in australia
king kolton9 says: Jun 17, 2011. 5:18 PM
Why are they all 3 numbers?
mg0930mg says: Jun 17, 2011. 6:30 PM
Did you really just ask this question?
king kolton9 says: Jun 18, 2011. 7:50 AM
Yes I did. Why?
mg0930mg says: Jun 18, 2011. 9:43 PM
How old are you?
king kolton9 says: Jul 1, 2011. 4:01 PM
If find that is none of your buisness (sorry if that sounded scarcastic).
I was just wondering why instead of 911, we have 1, or 2, or 3, ect.
mg0930mg says: Jul 1, 2011. 4:18 PM
It's just easier to remember, and England didn't want 911. Australia wanted 000 they're easier then 911...
I was wondering because, to me at lest, it seems like a rather simple concept..
king kolton9 says: Jul 1, 2011. 5:04 PM
Correct me if i'm wrong, but 1 is is one of the easiest (and lonliest) phone numbers there are, and the 500 miliseconds spent dialing could very well save you life, though it's not likely.
finnaly, i ment mean in the perenthisies in my last comment.
mg0930mg says: Jul 1, 2011. 5:10 PM
Also easy to misdial.
king kolton9 says: Jul 1, 2011. 5:28 PM
As is 911 ( I'm not trying to be rude).
mg0930mg says: Jul 1, 2011. 6:12 PM
911 is in between being too long to dial, and fast enough to do even when hurt.
pro2xy says: Nov 9, 2011. 8:42 AM
Its so, because they are easy enough to remember, while at the same time, being 3 digits and that too on the opposite corners on a phone keypad (911), its not very likely a number that could be dialed accidently.
Moreover, were you people actually trying to fight over it? Lol.. :P
Hallmar says: Jun 6, 2011. 9:57 AM
@ =SMART= This is great idea and thanks for sharing it with us. Can i use another tin can besides this one like a Soda or beer can?
Amby-chan says: Jul 8, 2010. 12:13 PM
I think even if you did memorize your numbers really well, it's still good to have, so if your unconscious, someone can call them for you.
abadfart says: Jan 30, 2011. 4:27 AM
ya kind of like setting your ICE contacts on your cell phone
Knot71 says: Aug 4, 2010. 8:20 AM
I really like the idea of having your name on the tin!
LemonLily says: Mar 27, 2009. 2:37 PM
The key idea and the money keeping thing is cool. Thanks for sharing. But too bad I don't bike. I don't even know how...
littlebastard says: Jun 26, 2010. 9:12 PM
you dont know how to ride a bike?
shaunaaltman says: Sep 20, 2009. 6:27 AM
I'm going to make some of these as Christmas gifts.
merseyless says: Mar 27, 2009. 7:00 PM
dollardude says: Jul 24, 2009. 4:45 PM
you are sad homer (did you destroy springfield too?)
merseyless says: Aug 7, 2009. 2:29 AM
yes... along with scientology
shooby says: Jun 13, 2010. 8:14 PM
No tire (tyre) levers??
EFT4Me says: Mar 3, 2010. 4:11 PM
Lots of cool ideas. I realize space is limited but there are a few simple small things that can make a difference if you need them.  Ever try riding a bike with a headache or worse, toothache?  Jeez Louise, the bumps can be murder!  A couple of aspirins or Tylenol, a few antacids take up little space. In the dime stores they used to have a plastic poncho for 99 cents (folded up to 2''X 3'') that you could   duck tape under your seat.  Lastly, when thinking about the poncho I recalled another 'rubber'  type item.  Easily fits in the tin & can keep you healthy.  Extends  your life  while protecting against  other types of 'accidents'...Enough said?
allenmt says: Jan 1, 2010. 5:04 AM
 gr8 ible gonna make soon but need altoid tin
shaunaaltman says: Sep 20, 2009. 6:15 AM
I don't really ride a bike, but I'm going to make a kit as a gift. What is the sandpaper used for?
hammertong says: Dec 7, 2009. 7:03 PM
 The rubber cement that holds the tube patch in place sticks better if you rough up the area around the hole. Some patch kits come with a small piece of metal that resembles a cheese grater for this same purpose.
knektek says: Nov 2, 2009. 1:47 PM
in another altoids tin you can put the puncture repair kit a wrench, spare tyre (to fit your bike wheel) and a pump. ps# you would need about 4 or 5 tins for that lol.
shaunaaltman says: Sep 20, 2009. 6:29 AM
I wonder how difficult it would be to add a blinking red light to the front and some kind of clamp or velcro attachment to the back....Has anyone tried something like this?
godofal says: Oct 3, 2009. 9:04 AM
make a red led and a white led to it, and you also have a emergency light! add a small coin cell, 1 bright red led 1 bright white led, 2 resistors (100ohm should do it) , a switch and some way to attach it to your bike/body shouldnt take that much space...
cubesnail says: Jul 5, 2009. 6:40 PM
You should also put something for in case the chain brakes
1-40 of 182Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
