3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CAT FEEDING PLATFORM
This raised cat feeding platform will make feeding your cat a little easier on your back. You don't have to bend over all the time to fill the bowl. Rats can't raid the feeder, and there is also some entertainment value in watching the cat jump. It's a poor man's circus act, without the burning hoops.
All the parts are recycled materials. The base is a discarded fan base, 18" in diameter. The 15" diameter platform is a round piece of plywood from my scrap wood collection.
The pole in this feeding platform telescopes for height adjustment. It came from another fan base. When my cat was smaller, he needed a 5-gallon bucket set next to the platform as a step for getting up to the food. Not any more.
Step 1THE BASE
THE BASE
A good base is a wide base. This one measures 18" in diameter.
The wood under the platform has a hole that fits over the top of the vertical stand pole, thus securely holding the platform.
The feed bowl is made to slide on and off the piece of wood that protrudes from the side of the platform. I used some PVC material from pipe scraps to make the channel underneath the bowl that holds it in place.
11 comments
Feb 27, 2012. 4:25 PMToniRose says:
Looks like another advantage is that it's easy to clean under. You don't have to move the bowl out of your way to sweep or mop. (For some reason that always bugged me.)
Aug 19, 2009. 10:23 PMRedneckAsian says:
my family spends more money on cat food than dog food because my dog only eats cat food
Oct 18, 2009. 1:20 PMlibed91 says:
 same here, my dog also prefer cat food.
Jul 22, 2009. 9:56 AMwandalee says:
this is perfect, for us!! we have one very fat cat and this gets the other cats' food up out of her reach. I like that it uses a discarded fan base and the bowl holder is genius though I don't I'll be able to do it for myself. Thanks for the great idea.
Aug 10, 2009. 1:57 PMhishealer says:
I also had a problem with one cat getting his drink and knocking over the bowl, leaving the other one dry. Industrial strength velcro solved that problem! I found a flattish bowl I would otherwise discard, put the hooks on the bottom of it, and the loops part on the table where they drink. Six months later and the velcro is still attached. I think that may be a good solution here too.
Jul 23, 2009. 1:08 PMfangfriends says:
Till now, I've had to put the cat food high up on a book shelf where the house bunny can't get to it. But I have a better solution.
Jul 17, 2009. 8:11 AMRaisedByRobots says:
This has another purpose too. It turns out that raccoons can't jump, so this guy here built a cat feeder on a platform to foil the furry criminals. http://www.thewildones.net/raccoons.htm
Jul 16, 2009. 1:26 PMlemonie says:
New to me, good one! L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
337
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
