Step 5: Stick it on the wall
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
P.S. I used different dark colors on the CD. It came out pretty well! Try it!
but anyways i am really impressed with the use of useless CDs and it is really beautiful :)
Cut a small circle of thick card (just thicker than the cd but small enough so that it can pass through the hole in the cd) stick it to the greeting card, place the cd over the small circle. then glue a slightly larger piece of card over the first so the cd can spin freely.
Please reply. x
I don't know how it's going to affect the reflective surface of the CD, but probably will make it slightly duller. Though a layer of varnish is usually hardly visible. Warning: cover nose and mouth and spray it outside.
This is also a good way to destroy data without smashing the disk.
Of course, nothing can be done to eliminate the smell of toasted plastic from the CD.
