In the realm of assistive technology, a switch (aka "ability switch") can be anything from a plastic button to a muscle twitch sensor. This album is a great look at the variety of switches that are available. These switches are almost always wired to a 3.5mm (1/8") mono plug, and can be connected to anything with a matching jack. They are used with power wheelchairs, computers, speech devices, toys, remote controls, and so on.
The problem is that switches are expensive. A basic Jellybean Switch or Buddy Button costs around $50-60 (USD), for just a plastic button. While these are worth their weight in gold, the price is still a bit steep, especially in the low-budget/non-profit world of assistive technology.
Sometimes, it's handy to make your own.
Fortunately, a switch is a very simple thing. It's just a circuit closing, just two wires touching. We will use less than $10 (USD) worth of parts to let a person press a surface (in this case a CD), and touch two wires together. R. J. Cooper also sells CD Switch Kits for about $10 (USD) each, in packs of five or ten.
Save the left over scraps from this project, as you can use them to build a No-Solder Battery Interrupter, which you can use to let this switch control toys and other devices.
Remove these ads by
Signing UpStep 1Materials
Materials Needed:
- Adhesive backed copper foil sheet. 5"x10".
- Adhesive backed Velcro strip. 6" of each side.
(I used 3/4", but nearly any width should work. Foam mounting squares will also work.)
- 3.5mm mono cable with male jack.
(Buy a 3.5mm mono extension cable, cut it in half, and use the male end for this, and the female end to make a No-Solder Battery Interrupter.)
- CDs. 2.
(Old software, AOL trials, blanks, whatever you have laying around.)
Tools:
- Scissors
- Ruler
- Sharpie (or other fine point marker)
I haven't tried hitting one with a drumstick or a mallet, but it would probably work.
If you want to change the amount of force needed, change the "buffer" material that holds the discs apart. If the velcro is too much, try gluing in some soft cloth, a few piece of a sponge, or whatever you have on hand. I find that foam mounting squares work well ( http://goo.gl/yfupg ).
You just need a nice conductive surface on each CD, so that the circuit completes when they touch.
Don
Don
Don
Web Design Springfield MO
