CELTIC PENANNULAR BROOCH
8,231
273
23
Published
Introduction: CELTIC PENANNULAR BROOCH
A Celtic brooch, called also penannular brooch, made with a scrap piece of thick copper wire.
If you like it vote for me in the contests!
(from wikipedia) Penannular: ("Annular" means formed as a ring and "penannular" formed as an incomplete ring) brooches feature a long pin attached by its head to a ring; the pin can move freely around the ring as far as the terminals. There is a gap between the terminals wide enough for the pin to pass through. Beginning as utilitarian fasteners in the Iron Age and Roman period, and in Ireland and Scotland from about 700 to 900, which are popularly known as Celtic brooches or similar terms. The brooches were worn by both men and women, usually singly at the shoulder by men and on the breast by women.
Step 1: WHAT YOU NEED
MATERIAL:
-a scrap piece of thick copper wire (I tried with 12, 10 and 8 gauge and they all worked well, in this tutorial I'm using the 10 gauge).
TOOLS:
-hammer;
-hard still surface;
-round nose pliers;
-file;
-wire cutter;
-ring mandrel (or a tube of desired diameter).
Step 2: ANNEAL
Anneal the copper wire, it will make it more easy to work with.
Use pliers, as it became super hot!
Step 3: BEND
Bend the copper wire around your tube.
Step 4: CUT
Cut the piece almost to a full circumference, but not quite.
Step 5: HAMMER
Hammer the whole piece a bit,, and the edges more, so they will look like the ones in the photo.
Step 6: FILE
File the edges.
Step 7: CUT ANOTHER PIECE
Cut another piece of copper, longer than the diameter of the brooch.
Step 8: HAMMER AGAIN
Hammer the whole piece a bit.
Hammer flat an edge of about 1 cm (photo 1).
Hammer the other edge large (photo 2).
Step 9: CUT THE EDGE
Cut the edge you hammer large (not the 1 cm flat one, the other) like a point.
Step 10: FILE
File the two edges.
Step 11: WRAP
Wrap the 1 cm flat edge with the round nose pliers.
Insert it in the brooch.
Close it.
Step 12: HOW IT WORK
So the wrap that you made around the brooch should be large enough to allowed the spike to move freely around it, but small enough to be stopped by the wide edges.
The spike should be longer than the brooch, so it will be stopped by it, ones the brooch is in place.
The space between the two large edges of the brooch should be wide enough to allow the spike to pass by.
Step 13: PLACE IT
Open the brooch wide and insert the spike in the shawl (or whatever you are using it on).
Close the brooch.
Turn it (all the way behind the spike), and close it.
Step 14: DONE
Done!
You want one, but you don't feel to make one? Here is the ones I sell!
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
23 Comments
Very cool! I love these brooches, and had never thought to make one--you make it super-simple to follow along!
Very well done marcellahella! Simplicty at its best, I just love it!
Oh, thank you! I knew I was going to need to make something to hold closed the wrap my dear daughter in law knitted and sent to me. This will be just perfect! I love that it's all in one piece as we have and foster Cairn Terriers and I wouldn't want one to swallow a small piece!
You are welcome! If you do let me know how they turn out!
So, you annealed the copper to soften it, can you heat treat it to make it harder?
I don't know about heat treat it to make it harder, but when you hammer it, it became super hard again.
True, work hardening would for sure do it, especially with copper.
Awesome! Enter this in the jewelry contest...gets my vote!
It is in the jewelry contest, thanks for the support!
Great instructable. I love the simple elegance of the finished brooch.
Are you using any kind of finish to keep the copper from turning green?
No, I like the natural patina that copper get after a wile. Also copper items generally don't turn green if they don't get wet, just a darker color patina.
Also for example bracelets and rings if they get used a lot they stay super polished naturally, for some reason. They may just leave some green on the finger, that I don't mind.
But there is many waxes and other product available, if you like a shiny look.
I've made some of these in the past when I was involved with an historical society. I haven't done it in a long time, and this seems like a nice quick gift I can make in the days before Christmas.
great 'ible!
