Many people believe that these ovens are novelties and can not be used for anything. The truth is this oven heats up very fast and care should be taken when handing it or any contents when at operating temperature. Under spring weather conditions and when pointed properly at the sun on a clear day, it will pass 150°C (300°F) within 10 minutes.
Remove these ads by
Signing UpStep 1Supplies and Materials
Several Different Sized Boxes (some very large ones are useful)
Clear Packing Tape
Styrofoam Packing Peanuts or Shredded Paper
Razor blade
Black Spray Paint (enamel) or Black Enamel Paint in a can (you should not use latex paint)
Scissors
Paper Clips
Aluminum Foil (heavier and shinier the better)
A piece of Glass or Acrylic
Glass cutter (if glass is used), a Saw (if acrylic is used)
Rubber Bands
Can to cook food in
Short pencils or dowels which no longer have a use
A ruler (yard or meter stick would be best)
Pen or Pencils
Calculator
Optional:
Thermometer Probe to monitor temperature
Or wouldn't a black ceramic lidded cooking pot work inside the chamber without the glass lid?
I am thinking of camping and such where you wouldn't want to cary the glass around, as well as weekend yard cooking.
I'm now building a big box type with sun tracker... Am doing a instructable for it so keep your eyes open... Should have it finished by xmas 2010....
That way, no glass at all! You might get less energy in because it is all reflected and none direct but you could have the top super well insulated and there would be much less convection losses from under the oven.
A guy called David Delaney thought of that years ago but I do not think he ever tried it.
The glass used should be TEMPERED GLASS. I know that will make it hard to cut, but I built one of these using quarter inch (6 mm) plate I picked up somewhere. After adding the reflectors, I saw using an oven thermometer, the temperature had reached 350 degrees F (175 C), grabbing my camera, I leaned over to take a picture, letting my shadow fall across the glass. When I leaned away again I heard a "CLINK!?!"
Looking back, the glass had broken. It didn't shatter, it cracked in a wavy pattern from one side of the glass to the other, perpendicular to the surface of the glass. Though that sounds anti-climactic, the edges were still "sharp as glass."
For years, all across Texas, tempered automobile back glass windows have shattered during the summer months due to being parked in the hot sun with all the other windows closed. It has happend to me once, and I have known several people over the years who have experienced the same problem.
Therefore, Tempered glass is no improvement, AND you CANNOT CUT Tempered glass AFTER it has been tempered. It HAS to be cut/shaped, and edges finished BEFORE TEMPERING. I got this info from a Tempered glass fabricating company years ago.
However, if you have a piece of tempered glass to recycle, e.g. from a refrigerator shelf or whatever, you could design the oven around it.
IF the edges of one's multiple glass panels are properly fitted, the millimeter, or so, air gap will not be significant in the escape of either heated air, OR reflected infrared energy.
So, to make a larger opening, use multiple pieces of Tempered glass windows from whatever source.
So just like concrete roads need expansion joints, it seems that glass needs them too in solar ovens.
My first solar oven was one we made from a foam cooler box. We cut the front 33°, as that seemed to be the best angle for the sun in S.Cal. The glass we had cut from double strength~~never even thought of tempered way back then. It was lined with foil, with a black cloth on the bottom (over the foil) and the reflector was made of three asphalt floor tiles covered in foil. Favorite thing to cook was Jalapeno/cheese strata.
Rated and featured.
