CFLs(Compact Flourescent Lightbulbs) are getting cheaper and better in every way. But meanwhile flourescent lightbulbs for aquariums at my local fish store costed around 12 bucks and seem to be getting more expensive. It diddn't help that my aquarium hood light's circuitry was all rusted and broken and bulbs would burn out on a weekly basis because of it. Finally I was fed up with it all and decided to do something about it.
At first I found the instructables on how to make an led light. I thought I would do that but when I went to Fry's Electronics I found out that it would be like 40 dollars to by all the led's I needed. I couldv'e bought them online but being my impacient self, I diddnt. Plus I diddn't like all the tedious soldering that went into everything.
Finally I came up with this: The Compact Flourescent Aquarium Hood Light
some benefiets are:
-No soldering!( YAY)
-Easy to aquire materials
-Brighter aquarium
-Cheaper to replace bulb
-Every time you replace the bulb it also replaces all the circuitry so it'll last a long time
Remove these ads by
Signing UpStep 1Things You Need
-Aquarium hood light
-CFL Bulb
-Not needed desk lamp
-wire connectors- rated 120 volts (I found these in the old circuitry of aquarium hood light)
-Sheet metal or Aluminum Foil (I used sheet metal but aluminum foil would probably work just as well)
Tools:
-Hot glue gun
-Screw driver (for taking out the circuitry of hood light)
. As lemonie points out, fluorescent tubes for aquaria output a different color mix than CFLs (or maybe I should say that I haven't seen any CFLs labeled for aquarium use). Any live plants may suffer (but the increased overall light level may make up for it).
It is more critical when using fluorescent bulbs with reptiles or with corals. These applications do need full spectrum.
The aquarium tubes are expensive because they output at higher colour-temperatures than other fluorescent tubes, this will have some effect upon the tank & things living in it.
L
colour temperature is something else though.
L
yes, full of information that, good find.
L
I would actually add a step that will make the CFL last longer as well as make it much safer, and that would be to put a bead of silicone in the groove that goes around the base of the CFL. These bulbs are not meant for use in moist or damp areas, and the moister wicks into the bulb shorting the circuitry.
