3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CHEAP Foam Soap
CHEAP Foam Soap
Have you ever wondered if you could make soap cheaper? Well I have, SO I one day I was thinking "I wonder if you could make your own foam soap?" So off I went to the dollar store and picked up these items I played around with them until I came up with this mixture...its REALLY CHEAP...and these days thats what everyone is looking for :) Hope you ENJOY!!!!
Step 1Foam Bottle
Foam Bottle
Find a bottle of Foam soap (the bottle should look like this picture or pretty close) use until empty.
13 comments
Feb 16, 2012. 5:06 PMmelharvey says:
I read why the pump starts sticking on a site that sells foam pumps-- cheap but the shipping is min. 10 bucks--http://www.bottlesandfoamers.com/cart/foam-pump-instructions-c-20.html
"The pump mechanism has a small amount of lubricant in the chamber to keep the pump moving smoothly. This will break down over time and cause the pump to stick. You may pull the pump apart and add a small amount of lubricant to keep the pump from sticking. Any silicone base or water insoluble lubrication will do."
You can get the silicone lubricant at the auto parts store-- ask for the stuff that keeps the old seals on the car door from sticking in the winter.
Also they say don't use them in the shower-- because of getting water into the pump mechanism.
But sticking seems to be the main problem over time, so that looks like an easy fix. The can of lubricant will last forever, most likely. And if your car doors start sticking, you're ready for that too.
Aug 27, 2011. 8:54 AMwhisperonthewind says:
You can buy new foam pump bottles online, easily and cheaply. And any liquid soap will work, including shampoo or bath gel. I use about 1/6 hand soap to 5/6 water, a little more shampoo in the mix for foamy shampoo (saves time! works just as well), and for bath gel or bubble bath, you have to try it. For me, bath gel was about 1/8 gel to 7/8 water, and bubble bath was closer to hand soap in strength.
And if you clean the foam pump part with anything, either vinegar or water or a mix, let it dry for a couple days before trying to use it again. You want it REALLY dry. And if it just doesn't work after that but you like the bottle, you can also get replacement pumps online! Google is your friend.
Dec 4, 2010. 9:14 AMMetroidMan347 says:
I did some of my own experiments, and I found the purple anti-bacterial soft soap (or the rip-offs of it) worked almost perfectly to the standards of the commercial stuff. I fill mine with slightly less than 1/3 of a bottle, water, and a little more than 1/3 soap. That's what seems to work best for me.
Jan 28, 2010. 5:18 PM35Timmy says:
  thank you
 now i can  finally  pervent the air  from getting filled with diease
  from my sister's flu
 and now i can have a  safer and healther air   becuase my sister has
Aug 22, 2009. 12:41 PMelizabethd22 says:
In other posts online on this topic, I have seen it recommended to pump a vinegar solution through the pump if it stops working. The vinegar cleans the water deposits off the mechanism so it frees things up and gets it working again.
Feb 10, 2010. 4:00 PMScannerWA says:
I've been doing this with Walgreen hand soap and the Walgreen foaming soap bottle for over a month now. Just recently (over the last couple of days) the pump started getting sticky (getting stuck in the DOWN position) so I just unscrewed the top and pumped warm water through it, problem solved, it's back to it's functional cost reducing effectiveness again. :)
Jan 14, 2009. 7:43 PMtiyospe says:
is this just plain soap or does it actually foam when you pump it?
Oct 16, 2008. 5:18 PMdchall8 says:
I've tried this with Dawn dish soap in two different Dial foamy pumps, and for some reason the pumps broke. It worked fine at first but became harder and harder to pump with time. I thought it might loosen up if I went back and used the official Dial refill soap but it didn't. It seems like the Dawn foamy dish pump is made better than the Dial foamy hand soap pump. I've been using Dawn pumps with generic foamy refill soap for awhile. I should try one of them with diluted regular dish soap.
Oct 16, 2008. 10:52 AMScott_Tx says:
What I do here. I use about 1/4 'ultra' type dishwashing soap to 3/4 parts water. I like the foam better cause it doesnt wash off your hands as soon as you start scrubbing like the gel does.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Dixiechick20
