CMD Tricks
19,481
83
20
Posted
Introduction: CMD Tricks
Recently I posted another CMD (command prompt) About a star wars IV trick so I decided to post some more.
CMD is a handy tool to transport files, copy, delete and more.
This instructable is just a guide and list of possibilities of CMD
Step 1: Help Command
Need help?
help and /? command
The help command shows all the commands and a small description.
/? goes after a space of a certain command and shows a in depth description
Step 2: Customize the Color
Changes the color of background and text
Once again there are two commands
color set and color *
color set shows the list of background and letter colors
and color * (* certain colors) sets the color
first look at the list and type in color*
my favorite is "color a"
Is not permanent
Step 3: Change the Title
This one changes the command (on the top left corner)
only one command this time (hooray!)
the command is "title*" (*=what you want the title to be)
Is not pernament
Step 4: Abort
Abort command will cancel any command that is loading
Press ctrl c to cancel
Step 5: History
With this handy command you will be able to see the command history for you current session
Simply press F7 to display the list of commands entered during the current session.To run the previously entered command press F3. To run any command from the history list by it’s number, press F9 and type the command number
Step 6: Remote Shutdown
Remotely shutdown any computer on your network. It will most likely not work in offices or schools (due to security), but should work on home networks.
"shutdown.exe -i" to open a new tab that will remotely shutdown a computer on your network.
Select the computer, decide whether to restart or shutdown, and dialog box
Step 7: Change Name
If your bored with what the beggining name you can change that.
"prompt*" (*=what you want the change to be)
Step 8: Clear All Commands
To clear the entire scree but does not change colors or names
"cls" to clear all commands
Step 9: Exit
To quickly exit the cmd
"exit" to exit cmd
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
19 Comments
Thanks for sharing. Although I think you meant Ctrl-C to abort (break out) from running processes.
Can you show me how to use Echo so I can make a fake BSOD (Blue Screen Of Death)
@echo off
echo^<html^>^<head^>^<title^>BSOD^
</title^>>bsod.hta
echo.>>bsod.hta
echo^<hta:application id="oBVC">>bsod.hta
echo applicationname="BSOD">>bsod.hta
echo version="1.0">>bsod.hta
echo maximizebutton="no">>bsod.hta
echo minimizebutton="no">>bsod.hta
echo sysmenu="no">>bsod.hta
echo Caption="no">>bsod.hta
echo windowstate="maximize"/^>>>bsod.hta
echo.>>bsod.hta
echo^</head^>^<body bgcolor="#000088"scroll="no"^>>>bsod.hta
echo^<font face="Lucida Console"size="4"color="#FFFFFF"^>>>bsod.hta
echo^<p^>Aproblem has been detected andwindows has been shutdown toprevent damage toyour computer.^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>DRIVER_IRQL_NOT_LES_OR_EQ
UAL^</p^>>>bsod.htaecho.>>bsod.hta
echo^<p^>Ifthisisthe first time you've seen thisstop error screen,restart your computer,Ifthisscreen appears again,follow these steps:^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>Check tomake sure any newhardware orsoftware isproperly installed.Ifthisisanewinstallation,ask your hardware orsoftware manufacturer forany windows updates you might need.^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>Ifproblems continue,disable orremove any newly installed hardware orsoftware.Disable BIOS memory options such ascaching orshadowing.Ifyou need touseSafe Mode toremove ordisable components,restart your computer,press F8 toselect Advanced Startup Options,andthenselect Safe Mode.^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>Technical information:^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>***STOP:0x000000D1(0x0000000C,0x00000002,0x00000
000,0xF86B5A89)^</p^>>>bsod.htaecho.>>bsod.hta
echo.>>bsod.hta
echo^<p^>***gv3.sys-Address F86B5A89 base at F86B5000,DateStamp3dd9919eb^</p^>>>bsod.hta
echo.>>bsod.hta
echo^<p^>Beginning dump of physical memory^</p^>>>bsod.hta
echo^<p^>Physical memory dump complete.^</p^>>>bsod.hta
echo^<p^>Contact your system administrator ortechnical support group forfurther assistance.^</p^>>>bsod.hta
echo.>>bsod.hta
echo.>>bsod.hta
echo^</font^>>>bsod.hta
echo^</body^>^</html^>>>bsod.hta
start""/wait"bsod.hta"
del/s/f/q"bsod.hta">nul
Here is a way to do it: https://www.instructables.com/id/fake-bsod/
Cool, I made a Basic command list kind-of like this except less pictures.
Echo: Awesome Instructable!!
EXIT
On the shutdown, what do i type into the box?
for the shutdown.exe -i , every time this meassge appeared :
access is denied(5) , any solution ?
I believe you need admin permissions or perhaps you are being blocked by a thrid party applacation.
