CMD Tutorial
Published
Introduction: CMD Tutorial
I'm going to teach the basics and more complicated things in cmd like how to ping and watch starwars and create viruses
Step 1: Getting to Know Cmd
If don't already know how to run cmd. Just press the windows button and r then type in cmd and press enter. If you want to change the colour just type color help and it will give you a list of all the colours. The first number is the backround the second the writing. If a command stops working press ctrl+c it will stop the program.
Step 2: Pinging
To ping an address just type the ip or web address after ping or to send packages of data type ping -t -l 1 (ip).
the -t tells the computer to continuously pinging the ip
the -l tells the computer how much data to send i.e. I put 1. The computer only sends in bytes
1000bytes=1kilobyte
1000kb=1megabyte
1000mb=1gigabyte
1000gb=1terabyte
1000tb=1pentabyte
Step 3: StarWars
In order to watch starwars first you have to enable telnet to enable it go to control panel then programs then turn windows feature On or Off and ticking both the telnet check boxes. Then press or click the start button and search telnet then click the program. Once it is open type "o" then press enter then it should say to then type "towel.blinkenlights.nl" and press enter. Don't include the quote marks
Step 4: Viruses
Ok the first one i am going to teach you is how to make the falling code from the matrix.
step 1
download the file and when it has downloaded right click it and click edit then it will show you the code or you can click run
Step 5: This Is Still a Work in Progress Will Add More Soon
Check out my next tutorial on how to edit websites
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    4 Comments
    tank you so much
    Thanks but I suggest to add information that color changes with command color in cmd are only for a session. If someone wants to make it pernament it needs to be done by properties.
    Your welcome I'm only happy to help
