Introduction: CNC Stomp Pad Project | CNC Programming | G-Code Programming | CNC Plasma Cutting
This Instructable is about making a custom stomp pad for a snowboard. It uses CNC Design, CNC Programming and CNC Plasma Cutting to get the entire job done. It first starts out on the computer side of CNC, then moves on to the Machining side of CNC.
You can also view the project at:
http://www.cncinformation.com/CNCBlog/
Then on the left click on the video series. I am trying to video each step in the CNC Process so people new to the Hobby can get an overview.
Thanks,
Ivan Irons
Machine Tutorial
Learn CNC
Step 1: CNC Stomp Pad 1 | CNC Project Intro | CNC Tutorial Video | CNC Plasma Cutting | G-Code Programming | CAD | CAM | DIY CNC | GCode
CNC Stomp Pad 1 | CNC Project Introduction | CNC Tutorial Video
CNC Project that is shot in a tutorial sequence. It goes from the Design, CAD, CAM, Control, CNC Plasma Cutting and then final as CNC Project that is shot in a tutorial sequence. It goes from the Design, CAD, CAM, Control, CNC Plasma Cutting and then final assembly. Check out this CNC How-To.
First we go over the project goals and why we are doing this. We also outline the steps of the project and also the software we will use.
Thanks,
Ivan Irons
CNC Information
CNC Blog
Thanks,
Ivan Irons
CNC Information
CNC Blog
Step 2: CNC Stomp Pad 2 | CNC Design Illustrator | CNC Creative Design | CAM G-Code Programming | CAD | CNC Art | Artwork CNC | CNC Plasma Cutting
CNC Stomp Pad 2 | CNC Design Adobe Illustrator | CNC Creative Design
In this next video we go over the design of the CNC Stomp Pad. We use Adobe Illustrator to sketch it out. We prepare something that a CNC Plasma Cutter could follow.
Illustrator is a great program to use to create Artistic CNC Plasma Projects. It is a pro at Vector Graphics which is something a CAD Program and CNC Machine can read. It is also very flexible on the artistic side of design.
Thanks,
Ivan Irons
Machine Art
G-Code Info
Thanks,
Ivan Irons
Machine Art
G-Code Info
Step 3: CNC Stomp Pad 3 | CNC Rhino CAD | CNC Computer Aided Drafting Work | CAD Blocks | Polylines | G-Code Prep | Computer Design | Engineer Designing Work
In this CNC Tutorial Video we go over the design in CAD. We resize it to our dimensions and then convert it into a DXF File. Finally the DXF File is ready for CAM.
We use Rhino CAD to go through and scale our project to the size of the snowboard. Rhino outputs just about any file time. We are after a DXF file and it can output muliple types of DXF Files. Perfect for our Project!
Thanks,
Ivan Irons
CAD Design
Drafting Info
Thanks,
Ivan Irons
CAD Design
Drafting Info
Step 4: CNC Stomp Pad 4 | CNC SheetCAM | CNC G-Code Programming | Computer Machining | Metal Work | CNC Cutting | Metal Cuts | DIY CNC | Hobby CNC
Here we set the CAM Programming parameters in SheetCam. Next we finalize the G-Code for the project. You also get a quick look at some CNC Post-Processing.
SheetCam in my opinion is the best CAM Software for plasma cutting. It is simple, makes your lead-ins and lead-outs and has multiple post-processors available. Perfect for any sort of customized G-Code you want.
We go through and prepare our project for the shop and CNC Plasma Cutting.
Thanks,
Ivan Irons
CAM Design
G-Code Program
Thanks,
Ivan Irons
CAM Design
G-Code Program
Step 5: CNC Stomp Pad 5 | CNC Mach 3 GCode | CNC G-Code Control Software | Computer Program | CNC Artwork | Art Part | Machining | Machine Program | Mach 3 Artsoft
In this video we go through Mach 3 to look over the g-code. We are checking to see if we have any problems before we go to the CNC Plasma Cutter.
Mach 3 is a great place to check your G-Code before you actually machine something. And why not. Why smash up your machine when you can run it in a great CNC Control Program and check to see if you have things correct.
Simulate a CNC Cut or cut air before you actually machine something.
Thanks,
Ivan Irons
Mach 3 CNC Program
G-Code Machine Program
Thanks,
Ivan Irons
Mach 3 CNC Program
Step 6: CNC Stomp Pad 6 | CNC Plasma Cutting | CNC Video Tutorial
Last video we checked our g-code to make sure our program was correct. Now we go out to the shop and do some work. We zero out the cnc plasma cutter and start cutting our aluminum stomp pad. Aluminum is interesting to cut on your CNC Plasma Cutter. For me it seems to take more energy to cut.
Once we are done, we look it over and note the slag or dross we will have to grind off next.
Thanks,
Ivan Irons
Plasma Cut Video Tutorial
Machining Books
Thanks,
Ivan Irons
Machining Books
Step 7: CNC Stomp Pad 7 | Part Griding | CNC Plasma Video Tutorial
When you cut something out with a plasma cutter there is slag left over you have to remove. This slag is officially called "dross" when it come to plasma cutting.
In this video we rough grind the cnc stomp pad to remove the dross. I call it "rough grind" because later we will use a DA Sander to smooth it all out.
Thanks,
Ivan Irons
Metal Part Grinding
CNC eBook
Thanks,
Ivan Irons
Metal Part Grinding
CNC eBook
Step 8: CNC Stomp Pad 8 | Sanding & Spikes | CNC Videos Tutorial | G-Code Programming | CAD/CAM Tutorial
During this CNC Video Segment we sand our CNC Stomp Pad with a Dual Action (DA) sander. We are taking out any deep scratches and giving it a matte finish. The CNC Plasma Cut part then is taken over to a stand.
We look at different traction spikes and how they will look. After selecting a spike type, we start laying them out. We layout some marks where we will drill holes in the next video.
Thanks,
Ivan Irons
Learn CNC Tutorials
Machining Information
Thanks,
Ivan Irons
Learn CNC Tutorials
Step 9: CNC Stomp Pad 9 | Drill Holes | CNC Learning Videos | G-Code Project | CNC Programming Video | DIY CNC
In this video we drill the holes in our CNC Stomp Pad. We need to add the traction spikes and they are really a screw and nut. We drill the holes then clean them out.
We bend the stomp pad while drilling and we must hammer it flat next.
A quick DA Sanding to make the pad look good, then we are on the the next step which is finalizing the CNC stomp pad.
Thanks,
Ivan Irons
Learn CNC Tutorials
Thanks,
Ivan Irons
Learn CNC Tutorials
Step 10: CNC Stomp Pad 10 | Assembly | Final Photos | CNC DIY Project | G-Code Programming | Learn CNC Steps | CNC Tutorials | CNC Programming
Here is the final video in the CNC Stomp Pad Tutorial Video Series. In this video, we go over the final assembly of the stomp pad. We go over how to add the traction spikes to the stomp pad.
Then we watch as we used double sided tape to adhere it to the snowboard. A little tricky as the tape is very sticky and we have lots of odd shapes to work iwth.
Finally we take a look at some final photos of the CNC Stomp Pad on the Snowboard.
One Final Note:
The Stomp Pad works perfectly. I love the fact you can customize your life with CNC.
See you on the slopes,
Ivan Irons
CNC Videos Tutorials
G-Code
One Final Note:
Ivan Irons
G-Code
