This Instructable is about making a custom stomp pad for a snowboard. It uses CNC Design, CNC Programming and CNC Plasma Cutting to get the entire job done. It first starts out on the computer side of CNC, then moves on to the Machining side of CNC.
You can also view the project at:
http://www.cncinformation.com/CNCBlog/
Then on the left click on the video series. I am trying to video each step in the CNC Process so people new to the Hobby can get an overview.
Thanks,
Ivan Irons
Machine Tutorial
Learn CNC
Remove these ads by
Signing UpStep 1CNC Stomp Pad 1 | CNC Project Intro | CNC Tutorial Video | CNC Plasma Cutting | G-Code Programming | CAD | CAM | DIY CNC | GCode
CNC Project that is shot in a tutorial sequence. It goes from the Design, CAD, CAM, Control, CNC Plasma Cutting and then final as CNC Project that is shot in a tutorial sequence. It goes from the Design, CAD, CAM, Control, CNC Plasma Cutting and then final assembly. Check out this CNC How-To.
First we go over the project goals and why we are doing this. We also outline the steps of the project and also the software we will use.
Thanks,
Ivan Irons
CNC Information
CNC Blog
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
http://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
