CNC Stomp Pad Project | CNC Programming | G-Code Programming | CNC Plasma Cutting by ivanirons
Step 4: CNC Stomp Pad 4 | CNC SheetCAM | CNC G-Code Programming | Computer Machining | Metal Work | CNC Cutting | Metal Cuts | DIY CNC | Hobby CNC
Here we set the CAM Programming parameters in SheetCam. Next we finalize the G-Code for the project. You also get a quick look at some CNC Post-Processing.
SheetCam in my opinion is the best CAM Software for plasma cutting. It is simple, makes your lead-ins and lead-outs and has multiple post-processors available. Perfect for any sort of customized G-Code you want.
We go through and prepare our project for the shop and CNC Plasma Cutting.
Thanks,
Ivan Irons
CAM Design
G-Code Program
http://www.cncinformation.com
http://www.cncinformation.com/CNCBlog/
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
