3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CNC Stomp Pad Project | CNC Programming | G-Code Programming | CNC Plasma Cutting
Step 7CNC Stomp Pad 7 | Part Griding | CNC Plasma Video Tutorial
When you cut something out with a plasma cutter there is slag left over you have to remove. This slag is officially called "dross" when it come to plasma cutting.
In this video we rough grind the cnc stomp pad to remove the dross. I call it "rough grind" because later we will use a DA Sander to smooth it all out.
Thanks,
Ivan Irons
Metal Part Grinding
CNC eBook
http://www.cncinformation.com
http://www.cncinformation.com/CNCBlog/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:ivanirons
I am an avid CNC hobbiest. I also set up a CNC oriented website called CNC information. Here is the address if you want to check it out: http://www.cncinformation.com
