Step 1: Your STUFF
Large scanner
Computer
Vector Drawing Program
CAM generator
Mach3, EMC, or similar (http://www.machsupport.com/) (http://www.linuxcnc.org/)
CNC Router (www.100Kgarages.com)
Tooling Bits
Baltic birch plywood – ¼” 5 ply or similar
Staple gun
X-acto, utility knife, something sharp
Sandpaper or foam blocks
Step 2: My STUFF
Patience
Dust collection system
Writing skills
Photography Skills
More tools
Bigger tools
Faster tools
Step 3: Scan Original Blueprints
Step 4: Drawing Programs
There are so many design programs out there (http://crunkish.com/top-ten-cad-software/) (http://www.freecad.com/). Some are free, some are not. Try the free ones, or the trial downloads, and spend some time assessing their capabilities. Make sure you look at what they can import and export. This will be important in moving your drawing files to the CAM generator (more about that later). The higher end ones have a steep learning curve and take a while to be comfortable with. The lower end and free are getting better all the time. Check out Sketchup (free) with the ruby script that allows output in .stl and .dxf formats. Sweet! (http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl)
I loaded the file into my CAD program and with node editing, smoothed the exterior curves, or as known in boat making, fairing the lines. Using created circles at each intersection within the internal trussing, I smoothed and cleaned up the intersections, thus replacing gussets that would have been present if built the traditional way.
Step 5: Output to CAM
Some drawing (CAD) programs have no way to get g-code from them. G-code is a language defining where the router must go to perform the task you have in mind and is generated by the CAM. Some CADs have CAM with them but they tend to be the pay-for types. For those of you who are using a CAD program that does not have this function, you’re going to have to find a separate one to do this. Here is some links. (http://www.rhino3d.com/resources/display.asp?language=en&listing=545)
(http://www.freecad.com/CAM_Programs/)) For those of you who want to learn about g-code there are sites that will show you what it all means. (http://www.cncezpro.com/gcodes.cfm)
(http://www.cnccookbook.com/CCCNCGCodeCourse.htm)
My program has CAM output, so the g-code was created, and ready for the homemade CNC machine.
Step 6: Selecting the Bit
Our router only goes one speed in rotation and maxes out at 25 linear inches per minute, so the only control we have is how deep it cuts per pass, and the inches per minute speed it travels thru the material. Before any machinery is turned on, install the bit into the router you have. Be VERY careful, they are quite sharp. I wouldn’t know that, but, there are a wide range of band aids and compresses readily available in our shop, just in case.
Step 7: Load the Material
Stabilize the cardboard (later the plywood). Many treacherous opportunities lie here. Cut the cardboard/plywood larger than the project. You want extra room for clamping down the outer edges with screws, cam locking devices, or even double-sided tape. I used a staple gun with ¾” staples around the outer edges of the cardboard and the baltic birch, out of the way of where the router bit would travel. Regardless of the method, one wouldn’t want the highly rotating router bit or the router itself crashing into something hard and unyielding. Some very interesting results WILL occur and you really don’t want that experience. The least is you may lose some steps in the g-code and get the remainder of the cut all cockety-wampuss, and the worst is flying bits of high speed steel flying around. Which brings us to the all-time favorite subject of OSHA, da-da… SAFETY.
Step 8: SAFETY
---Ears - CNC machines are loud. I like to put on noise cancelling earphones with my favorite music playing in the background. Not too loud as you want to lightly hear the machine as it runs, giving you a heads-up to any problems.
---Eyes and face – Flying objects do sometimes come from the machine, best to protect them. I use a face shield.
---Breathing – All materials have some dust created during the cut. Use at least a filter mask for non-toxic woods and cardboard something better for MDF and plastics.
---(If at all possible make or buy a dust collection system to keep the fumes and dust to a minimum. That’s the next project for us after this contest. Wish I had done it earlier.) (http://solsylva.com/cnc/vacuum.shtml)
Step 9: Power the Machine and Computer
Step 10: Zero, Zero, Zero
Step 11: The Magic
When the cycle ended, and the router came back to zero, I turned it off, then removed all the staples. I remove the waste sections, and vacuumed or blew off the dust so the machine is ready for the next experiment.
It almost worked perfectly. Several of the interior waste pieces moved around in an uncomfortable way, and two of the trusses bent out (got too thin) as the router bit pushed them sideways. Lastly, if the project is cut completely from the waste material, I have a template that will prove useful. So, I went back the CAD and placed a number of tabs around each part. (Tabs are small bits of the wood that hold all the various parts together. They are less thick than the plywood, short in length, and are easily cut with an x-acto knife.)
For this run I had the cardboard template to trace on a piece of Birch plywood. I could place staples more accurately to secure the material safely. Plan B was run thru successfully.
Step 12: Examine
Step 13: Finishing
I then met with the aircraft builder for his approval.
Now, only 31 more.
Step 14: Why We Want to Win
Our club of makers would continue to explore the vast world of CNC routing. We have in mind a large backlog of ideas that would be furthered by winning the PRS Standard 96-48-6 ShopBot . Our homemade CNC can cut 31” x 21” and cuts at a maximum of 25”/ min. The 4’ x 8’ table and 300”/min will vastly improve our ability to produce prototypes, develop and improve designs, create larger projects and test out 2.5D, then move to full 3D sculpting.
Here is a small selection of my personal list of projects:
2D
Mazes for more than one player
Multi-level mazes
Giant mazes on a half sphere to be played by young children
Interchangeable mazes of increasing difficulty
Picture frame mazes
Spirographs – small 8.5 x 11
Giant Spirographs using chalk for outside
Patterns for Cabinet doors
Wood Blocks for printing from ancient lithographs
2.5D
Bas-reliefs
Cameos
Negatives for molds
Negative busts
3D
Sculpture
Full Busts
Art prototypes
Thank you for considering this submission
Rick Shore
Visit Our Store »
Go Pro Today »
I hope you can help me. I have two Marske Flying wings that I want to build. 70% of the work is in making the ribs and making them to the correct size.
Thanks.
Wally
Pure plywood ribs should be designed for that lower strength of the material. Caps and diagonals should be much wider. And this will resulted in heaviest ribs, than odf classic design.
Othervise it is clever idea to simplify ribs manufacturing and to speed up the process. The newest design from team AeroMax use many CNC done wooden plywood parts in the aeroplane structure.
We always used a piece of sacrificial MDF under the material so we could cut all the way through. this also allowed us to pin the material - usually wood - down with panel pins. Much better than double sided tape and easier than various clamping systems.
A 30mm hole grid, 5mm holes, counter sunk to about 10 - 15mm in diameter?
The hole size is critical not too big but not too small.
Drill your thick plywood wood where the router cuts don't go close by and then counter sink them out.. to about 20mm in diameter.
Holding power = force x area.
And maybe route away one end and then apply a clamp to that, and perhaps a couple more as you go.
If I had to make any more than one or two of the spars like this, I'd make a table to suit the spar.
Make the table the exact same size and shape as the spar, perhaps add a couple of square "tabs" to clamp the sheet down and then lay the sheets on it.
The other thing is too, that you can make them in the stencil pattern.
Cut all of the shape out - except for a few connectors, that hold all of the pieces in place.
That way you can scrap the vacuum table and not have your timber and bits flying around everywhere around the router bit, when the cuts are made.
Once all of the cutting is made, then take a small hand saw of some description and cut the tabs.
Look up stuff on stencils.
And design it so the long thin bits are restrained as well as the thick bits and keep an eye on the cutting speeds... not too high.
Please don't take this as a disparaging comment, it's a great use for a CNC router, especially if it gets another airplane in the air. Well done!
Most of the traditional construction techniques, while they are good, there may also be other considerations that come under cost, wartime and efficient use of the resources - such as timber.
There was also the technical angle of the limitations of the equipment and the speed of production.....
It was deemed to be better to use a little glue and all the offcuts etc.. and to really minimise waste, than to be throwing out huge amounts of material, and it probably would have been far easier to cut lots of little straight bits from the one sheet, to assemble a spar from, than to try and cut out one as a single piece.
Not that they could not be pressed out with a knife press, but the smart people really factor in ALL of the considerations to get the most suitable product out the door at the best price relative to the market and circumstances.
There is some really great informaiton about designing and creating plywood and products from it.
The types of glues, the types of timber, they direction of the grain in the layers, in some regards plywood is the ultimate in wood porn.....
I guess that premium aircraft grade plywood is expesive, and if one were to knife presss and cut out, or route out or laser out whole spars from one single piece of ply, while I really like the idea totally - the amount of timber left from the sort of rectangular shape, would I guess, be about 5 to 8 times the amount of timber in the actual spar.
So I know that really GOOD aircraft grade plywood, that is free from knots and defects etc., IS really expensive, so with wages etc., it may actually be enormously cheaper, to cut that sheet up into lots of little straight bits and gussets, and to lick and stick them into a jig and then profile the finished component, than to throw away heaps of expensive timber.
