CNC machine for shaping large pieces of polystyrene foam
 by RTegelbeckers
Contest WinnerFeatured
Summary
This instructable shows how to shape polystyrene foam, using a CNC machine. Starting with a brief introduction, design software necessary for creating an STL file is discussed. This is followed by a method for creating G-code, using an STL file as input. After this comes the introduction to GRBL, an arduino based system for using G-code to control stepper motors of a CNC mill. Stepper drivers are mentioned, after which the creation of large CNC hardware is described. The instructable finishes with next steps.
Enjoy,
Richard Tegelbeckers
PS. I plan to expand/update this instructable as I gain experience and make improvements to my machine. Come back to check if you are interested! Also, if you would like more clarity on any of the steps, leave a comment and I will try to help out. I could potentially add more pictures as I took photos/videos of pretty much everything I did.
Step 1: Introduction
I became interested in CNC machines, shortly after being let down by a 3D printing firm in the UK. Intrigued with the reprap efforts, I decided that having a drill-like tool wizzing around in three directions would be an easy target to achieve. I did my research and ended up slapping together a small machine, using an old flatbed scanner, an ancient printer carriage and a defunct CD player. I learned from the experience and used it to come with the following objective: to create a large 3 axis CNC machine, capable of machining polystyrene foam. The machined foam can then be covered in a protective layer (eg. water based latex), before pulling a composite fibre mould(ing) from it.
cjc0306 says: Apr 16, 2013. 2:50 PM
Hi RT! Congratulations on a fine build. I am in the process of building a similar machine inorder to print some prototypes of my inventions. Since I have left over aluminum 1 5/8" tent poles laying around, I decided to build the foam cnc with them instead of square tubing. The current design Im prototyping measures 32" x 60", so I need a large machine. I have already built a 3D printer so Im pretty familiar with cnc technology. Any suggestions would be greatly appreciated, thanks.
RTegelbeckers (author) in reply to cjc0306Apr 17, 2013. 1:15 PM
Hi. How do want to connect the aluminium tubes to each other? Welding aluminium is not easy and usually requires a TIG welder.
In the near future I will make some alterations to my own machine. On the horizontal axes I want to further reduce the backlash and add gearing, by replacing each coupling with a chain and two sprockets. A ten tooth sprocket on the motor and a twentyfive tooth sprocket on the drive shaft will give a 1:2.5 reduction. Check my instructable in a few weeks as I will document the upgrades.
My z-axis is not very stiff in sideways direction, especially when the tool is all the way down. Not much of a problem for shaping large pieces of low density foam, but could be an issue in other applications.
Good luck wih your own machine!
Ajancnc says: Oct 9, 2012. 8:26 AM
Grate post! Thank you for this informative blog. Keep updating on this.
RTegelbeckers (author) in reply to AjancncOct 9, 2012. 10:56 AM
Thanks! I am a bit busy at the moment - preparing a new Instructable amongst other things - but I hope I will soon be able to make some updates to the big machine & this instructable. If you are into CNC, you might find my new instructable of interest. It should appear on this website in a few days...
PS. I assume you are connected to www.ajancnc.com somehow. May I ask in what way?
Vika84 says: Jun 21, 2012. 12:21 PM
Good Luck babe! xx
RTegelbeckers (author) in reply to Vika84Jun 21, 2012. 12:56 PM
Thanks gorgeous! Sorry for having spent the last two months in my workshop... xxx
FoolishSage says: Jun 5, 2012. 2:44 AM
This is a really cool build! Can you estimate how long it took and how much it ended up costing?
RTegelbeckers (author) in reply to FoolishSageJun 5, 2012. 9:27 AM
Thanks! The total cost for the small machine was £70 (mainly for electronics)and it took the occasional hour over a few months. The second, larger machine took several days over the last two months. The total cost for parts and consumables was £665. I also spend £28 on job specific tools, just as reamers (8mm & 10mm) and drill bits.
RTegelbeckers (author) in reply to RTegelbeckersJun 19, 2012. 8:26 PM
I noticed I missed out on a few items on my initial costing. I now worked out the total cost for parts and consumables as being £728. This does not take into account the materials I already did have. See step 6 for a Bill Of Materials.
mgingerich says: Jun 5, 2012. 6:07 PM
Have you considered building custom motor drivers? I'm making a CNC with from scratch electronics right now, and it's worked pretty well so far. Way cheaper too. Just something to think about. Great instructable!
robbert229 in reply to mgingerichJun 8, 2012. 10:45 PM
So I am not the only cheapo person on the web. That's nice to know, so how are you planning to build the electronics from scratch? I am sort of a person with shallow knowledge in this field, and would appreciate you sharing the knowledge that you have with me.
mgingerich in reply to robbert229Jun 9, 2012. 4:41 AM
I'd be happy to. My way of doing things was a little unconventional, since I'm controlling my CNC with a microcontroller. The schematic on page 3 of this instructable is the main part of my motor driver. four of these are needed to control one unipolar stepper motor. I'll let you know when I write a more detailed instructable on it.
mgingerich in reply to mgingerichJun 9, 2012. 4:42 AM
Here's the link: http://www.instructables.com/id/How-To-Make-an-Optocoupler/
robbert229 in reply to mgingerichJun 9, 2012. 1:15 PM
Very interesting, looks much easier than using some relays. Thanks! I shall be making my CNC's main chassis today. I just finished gutting a printer, and scanner, so now I have some steppers, worms, etc. The only thing is that I cant decide on what material to make the body. Wood, plastic, steel, I dont know what it should be made of, probably wood or steel though. Thanks for the insight, I have a picaxe 18x lying around that will work great with the opticoupler.
mgingerich in reply to robbert229Jun 9, 2012. 7:59 PM
Glad I could help :) What tools did you use to machine your steel? I'm restricted to wood so far because I don't have access to a shop. Let me know when you get your machine built!
RTegelbeckers (author) in reply to mgingerichJun 11, 2012. 11:52 PM
I have used a 'custom driver' on an x/y table I played around with, years ago. I used four PN2222 transistors, four MJE3055T transistors and four MJE2955T transistors to drive a single stepper. I used a DPDT relay to switch between the two stepper axes, losing holding torque in the process. The maximum current would have been in the order of 1A at 12Volt. I will now make a driver based on a Toshiba TS6560, which I can get for £2.24 each, incl. delivery: http://www.instructables.com/id/How-to-make-a-driver-for-a-stepper-motor/
The driver is not only good value, it also is economical on the ports needed on the microcontroler: per axis it only needs one line for steps and one line for direction. This means a bottom of the range arduino uno can easily handle three axes and will be left with a few lines spare. On top of this, it will allow for microstepping. This is essential on my rig as each step would otherwise be 0.4mm in size. It saves me from having to add a costly gear reduction to the motors..
ketirock says: Jun 8, 2012. 4:22 AM
Very Impressive.
Vika84 says: Jun 5, 2012. 11:17 PM
I managed to get movement by using the 12 volt pololu based electronics from my first, smaller CNC machine. In one direction the main carriage did move sort of ok, but in the other direction it needed a bit of help as it was jurky. The Toshiba based drivers running on 24 volt should in theory be good enough for the job. As I only give it a quick try, I hope I can still get them to work by tickering a bit more. Otherwise I will be very interested in your custom drivers!
PS. The price for the TB6560 drivers was pretty good: £36.65 for all three incl. delivery - source: Ebay
RTegelbeckers (author) in reply to Vika84Jun 5, 2012. 11:23 PM
OOPS! I was logged in under my wife's credentials for the last comments... Check out her instructables and especially the one for the Swan if you want to impress at a diner party!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
