loading
Step 2: Design software
In order to design something on a computer in 3D, (CAD) design software is needed. This might not be pleasant for the Fancy Apple folks or the Open Source Linux enthousiasts, but the system to use (in 2012) is boring old Microsoft Windows. Sorry, no discussion...
Having made the democratic decision for Windows (only one voter allowed: me...), the offering for CAD applications is plentiful and I advice to do plenty of research if you are serious about learning how to use a package. If budget is a constraint, 123D by Autodesk is hard to overlook. It seems to be relatively easy to learn and cannot be beaten on price as it is free. Be aware as it is still in beta stage (June 2012) and it seems troublesome on older, lower spec 32 bit systems. The 64 bit version should be pretty good on a more powerful machine. In the professional ranges the price for software climbs steeply, but one gets what one pays for... Popular offerings are Inventor by Autodesk and SolidWorks by Dassault. Both are very powerful and take a fair amount of time to learn.
In short: Use any CAD software you like as long as it can generate an STL file.
Something worth while mentioning, all softwares mentioned in the following steps are available as open source or freeware...
<p>Great Build! What type of coating do you use to protect the foam?</p>
<p>Another 3D CAD option, in about the same league as Autodesk Inventor or Dassault's Solidworks (though in my opinion better than either) is KeyCreator, by Kubotek. (<a href="http://kubotek3d.com">http://kubotek3d.com</a>) It is a professional grade 3D solid modeling program that also includes 3D surfaces, 3D wire-frame, and 2D drafting, all in one package. And since it is a &quot;direct&quot; modeler, it is free of the constraints common to parametric CAD programs. Another huge advantage, of direct modeling, is that it treats ALL solid models as native files. This allows you to revise and modify imported files, regardless of what program they originally came from. Inventor, Solidworks, Pro/E, STEP, IGES, whatever. It doesn't matter. Because KeyCreator does not depend on a feature, or &quot;history&quot;, tree, they're all treated if they were created in KeyCreator from the start. It's also easy to learn, with many on-line videos and tutorials. (PS: I don't work for Kubotek. I'm just a very happy customer/user.)</p>
<p>Hi. Lately there have been more offerings then when I originally published the intructable. The two most interesting ones in my opinion, are Onshope and Autodesk's Fusion 360. Both are cloud based and free versions are available, with monthly subscriptions for the more extensive versions.</p><p>Direct modelling has it's advantages, but so does parametric modelling. The most powerful option is to have both available.</p>
<p>I've been a parametric (Solidworks) user since 2003, because that's what my place of employment uses. And I've been through ALL the SWX training. I'm still looking for it's advantages. All it's ever offered me is frustration. Mainly do to the &quot;constraints&quot; getting in the way. (Why would anyone want to constrain themselves, anyway?)</p>
<p>Hi again. At the start of a design I often identify certain dimensions which are open for optimization. By carefully building up a model with this is mind, I am able to very quickly tweak these dimensions in conjunction with immediate updates to the model. I find this incredible powerful for machinery design, although it does require some planning from the outset. If using a parametric package like SolidWorks for more organic shapes, I can imagine it would be frustrating due the lack of direct modeling tools.</p>
<p>With KeyCreator, I don't have to give it that much pre-thought. I just go in and design. And any changes I decide on are simple and quick. KeyCreator has numerous different tools for moving, resizing, adding and/or removing geometry. And you don't have to worry about your model crashing because a parent/child relationship has been broken/corrupted or a constraint has been violated.</p><p>In my opinion, it's so much better than Solidworks, that when the company transitioned to SWX (in 2003) I bought a seat of KeyCreator myself. And I still use it (when I can get away with) for many projects.</p><p>Because we're a contract manufacturer, we work a lot with imported files. From all the &quot;major&quot; CAD programs. Anyone who has imported a parametric model from, say, Pro/E into Solidworks, know what a &quot;dumb solid&quot; is. I don't have that problem. Because KeyCreator works off the model's geometry, rather than a history tree, it treats ALL imported files as if they are native KeyCreator files. That's a huge advantage when I need to revise a customer's part, to make it manufactureable.</p><p>I've been using both, side by side, for over 12 years now. I'll take direct over parametric any day.</p><p>(Another advantage to KeyCreator is, though it is a full featured 3D solid modeler (along with 3D surfaces &amp; 3D wire frame), it also still retains its full 2D drafting capabilities. And you can mix &amp; match all of these tools in the same file. Very handy - and quick - when working out angles, dimensions, and different shapes.)</p>
<p>Hi friend, your project is good :)</p><p><br>Can you tell me, do you know where I can find electrical scheme of driver Toshiba tb6506 ? Thank you in advance</p>
<p>Hi. In the end I did not have to build my own drivers, as I managed to buy a set of YOUCNC drivers on Ebay. They were very cheap and they work very well. Although I have not used it myself, this might be a good starting point: </p><p>https://www.instructables.com/id/How-to-make-a-driver-for-a-stepper-motor/</p>
hello, I really like your project and I would like to do it. Can you help me please how to connect all electronics parts or how to program the arduino? <br>Thank you
nice
Cool machine! Do you have any pics of the part you molded from the mold you showed cut in this instructable? I'd love to see the finished product.
Thanks for your comment! The red gel coat resin I used was over ten years old, having been at the bottom of a badly sealed bucket. As such it did not want to harden out properly. I applied the laminating resin with extra hardener in the vain hope to compensate. This only resulted in the generation of too much heat, which caused the melting of the polystyrene mold in certain places. I left the part in a corner of my workshop as after several days the gel coat was still tacky. By now it must be ok to still do something with the part. As you reminded me by posting your question, I will dig it out next time I am in my workshop and finally finish it off! In the first week of July I have some panels to machine on the big CNC, so I will have a go at it whilst 'babysitting' the machine. Pictures will be posted soon after that...
Hi RT! Congratulations on a fine build. I am in the process of building a similar machine inorder to print some prototypes of my inventions. Since I have left over aluminum 1 5/8&quot; tent poles laying around, I decided to build the foam cnc with them instead of square tubing. The current design Im prototyping measures 32&quot; x 60&quot;, so I need a large machine. I have already built a 3D printer so Im pretty familiar with cnc technology. Any suggestions would be greatly appreciated, thanks.
Hi. How do want to connect the aluminium tubes to each other? Welding aluminium is not easy and usually requires a TIG welder. <br> <br>In the near future I will make some alterations to my own machine. On the horizontal axes I want to further reduce the backlash and add gearing, by replacing each coupling with a chain and two sprockets. A ten tooth sprocket on the motor and a twentyfive tooth sprocket on the drive shaft will give a 1:2.5 reduction. Check my instructable in a few weeks as I will document the upgrades. <br> <br>My z-axis is not very stiff in sideways direction, especially when the tool is all the way down. Not much of a problem for shaping large pieces of low density foam, but could be an issue in other applications. <br> <br>Good luck wih your own machine!
Good Luck babe! xx
Thanks gorgeous! Sorry for having spent the last two months in my workshop... xxx
This is a really cool build! Can you estimate how long it took and how much it ended up costing?
Thanks! The total cost for the small machine was &Acirc;&pound;70 (mainly for electronics)and it took the occasional hour over a few months. The second, larger machine took several days over the last two months. The total cost for parts and consumables was &Acirc;&pound;665. I also spend &Acirc;&pound;28 on job specific tools, just as reamers (8mm &amp; 10mm) and drill bits.
I noticed I missed out on a few items on my initial costing. I now worked out the total cost for parts and consumables as being &Acirc;&pound;728. This does not take into account the materials I already did have. See step 6 for a Bill Of Materials.
Have you considered building custom motor drivers? I'm making a CNC with from scratch electronics right now, and it's worked pretty well so far. Way cheaper too. Just something to think about. Great instructable!
So I am not the only cheapo person on the web. That's nice to know, so how are you planning to build the electronics from scratch? I am sort of a person with shallow knowledge in this field, and would appreciate you sharing the knowledge that you have with me.
I'd be happy to. My way of doing things was a little unconventional, since I'm controlling my CNC with a microcontroller. The schematic on page 3 of this instructable is the main part of my motor driver. four of these are needed to control one unipolar stepper motor. I'll let you know when I write a more detailed instructable on it.
Here's the link: https://www.instructables.com/id/How-To-Make-an-Optocoupler/
Very interesting, looks much easier than using some relays. Thanks! I shall be making my CNC's main chassis today. I just finished gutting a printer, and scanner, so now I have some steppers, worms, etc. The only thing is that I cant decide on what material to make the body. Wood, plastic, steel, I dont know what it should be made of, probably wood or steel though. Thanks for the insight, I have a picaxe 18x lying around that will work great with the opticoupler. <br>
Glad I could help :) What tools did you use to machine your steel? I'm restricted to wood so far because I don't have access to a shop. Let me know when you get your machine built!
I have used a 'custom driver' on an x/y table I played around with, years ago. I used four PN2222 transistors, four MJE3055T transistors and four MJE2955T transistors to drive a single stepper. I used a DPDT relay to switch between the two stepper axes, losing holding torque in the process. The maximum current would have been in the order of 1A at 12Volt. I will now make a driver based on a Toshiba TS6560, which I can get for &Acirc;&pound;2.24 each, incl. delivery: https://www.instructables.com/id/How-to-make-a-driver-for-a-stepper-motor/ <br>The driver is not only good value, it also is economical on the ports needed on the microcontroler: per axis it only needs one line for steps and one line for direction. This means a bottom of the range arduino uno can easily handle three axes and will be left with a few lines spare. On top of this, it will allow for microstepping. This is essential on my rig as each step would otherwise be 0.4mm in size. It saves me from having to add a costly gear reduction to the motors..
Very Impressive. <br>
I managed to get movement by using the 12 volt pololu based electronics from my first, smaller CNC machine. In one direction the main carriage did move sort of ok, but in the other direction it needed a bit of help as it was jurky. The Toshiba based drivers running on 24 volt should in theory be good enough for the job. As I only give it a quick try, I hope I can still get them to work by tickering a bit more. Otherwise I will be very interested in your custom drivers! <br> <br>PS. The price for the TB6560 drivers was pretty good: &pound;36.65 for all three incl. delivery - source: Ebay
OOPS! I was logged in under my wife's credentials for the last comments... Check out her instructables and especially the one for the Swan if you want to impress at a diner party!
About This Instructable
73,028views
297favorites
License:
Bio: I am a Dutch design engineer, living in Wales (UK) and working in steel industry until recently, as my request for voluntary redundancy did get ... More »
More by RTegelbeckers:3D Printed spectrometer, using Public Lab DIY kit. DeltaTrix 3D Printer Foot operated log splitter
Add instructable to:
