CNC machine for shaping large pieces of polystyrene foam
 by RTegelbeckers
Contest WinnerFeatured
Step 3: G-code
As soon as an STL file is present, G-code can be created. The program I use is called Freemill: http://www.mecsoft.com/freemill.shtml
It is very easy to use, but it could cause some issues with your graphics card. If it locks up, try the following: redo the steps until the last step before it would lock up again. Now shrink the program window or move it off screen, in order to prevent the 3D model from showing on your screen. The program should now work without crashing...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
