3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CO2 Drain Cleaner Hack
A while back, we had a slow running drain that seemed to be permanent.  I came across a product called "Kleer Drain" that uses CO2 cartridges to blast through clogs.  I thought it was worth the attempt, so I picked one up at Home Depot.
Boy, did it work... Not only that, but it made an extremely satisfying "whump" sound that sent me out to the hardware store to pick up more cartridges so I could attack all of our drains, plugged or not.
The problem is, the device also requires a single shot plastic disk that allows pressure to build up before it bursts.  When it does, the resulting explosion is what actually blasts through the clog.  These disks are no where to be found, except from the manufacturer... And they're both pricey and in short supply.
They look like Tyvek, but they're not.  Tyvek doesn't burst under CO2 pressure.  Certain types of paper may work, but when I thought about the work of having to cut all those disks out, I came up with a better solution that seems to work pretty well:
Step 1How Kleer Drain Works
I love this device, but it has some flaws.  First is the need for CO2 cartridges.  The Kleer Drain comes with a couple, but if you're like me, you'll use them all up in an hour or two.  Trust me... This thing is fun to use:)
The same goes for the plastic disks, but they aren't so readily available.  The only place I was able to find them was on the manufacturer's website.  And they cost a gazillion dollars for a half dozen... And they only came with additional cartridges (which cost another half gazillion).
I think the company may be using the inkjet printer profit model... sell the printer at cost and make money on the ink.  I have no problem with that, but I don't want my fun eating up my savings, or discover I don't have the parts I need in an emergency.
Enough commiserating, lets hack a solution!
11 comments
Jan 27, 2012. 12:22 AMwaldosan says:
for some reason i doubt the hospital will hand out used syringes, of course i've never asked so they might.
is there some kind of retail alternative that i could use to find syringes?
Jan 27, 2012. 5:41 AMThe Green Gentleman says:
You can get free syringes from a pharmacy (chemist - UK). These are (ostensibly) for dosing children's medication, but we all know better. They're for experiments! They're not huge, but might do the trick.
Feb 4, 2012. 10:54 PMkill-a-watt says:
Looks like you can ship-to-store for the disks things. Not too pricey, but I prefer your solution anyway:
http://www.homedepot.com/Kleer-Drain/h_d1/N-uhZ5yc1v/R-100083282/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
Here's some 30 ml ones for sale, probably too big:
http://www.sciplus.com/singleItem.cfm/terms/15976
Jan 27, 2012. 12:04 AMsnotty says:
Nice device.
My trick for drains is coat hanger wire:
1. Straighten a coat hanger.
2. Use the hanger to pick out and remove hair/crud near the drain's mouth.
3. Jam the hanger down the drain.
4. Turn on the tap to flush away the debris you're about to loosen.
5. Pump the wire in and out while rotating it to scrub away crud.
6. Expound.
This method works every time for me. I think most blockages are near the start of the pipe.
Jan 23, 2012. 3:05 PMjeffeb3 says:
Can you use an air compressor instead? Reusable, larger pressures...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:bfk(Children in Freefall)
I'm a lucky man with a beautiful wife and a 3D printer on the way. The best thing is, she wants me to spend my time inventing things for us to use around the house. A true win-win situation. I'm lo...
more »
