CO2 Laser Honeycomb Table Replacement
7,285
16
5
Posted in TechnologyReuse
Introduction: CO2 Laser Honeycomb Table Replacement
Started out by not wanting to blacken my good honeycomb table I use for acrylic by cutting craftwood and and other stuff on it.
Several months ago, the radiator in my wagon blew one of the tanks off the end and had to be replaced. I was about to take it to the dump when I noticed the similarity of the structure to my honeycomb table.
The rest was simple.......
Step 1:
Make sure you are using an aluminium radiator
Mark to length and cut the radiator using an old timber saw.
Step 2: Done
Side by side....
In the machine.....
Took all of 10 minutes.
The only change I would make is to pressure wash it before cutting, less messy.
Small update - Gaffer Taped the raw edges.
24/6
Tips.
When working with thin plywood, I have found that I can flatten the sheet by planning several points in void areas about 2 mm dia on a different layer in the software. Cut this layer first and pause the laser to screw the sheet down to the radiator. The two flanges which were left are convenient for clamping the edges of the sheet flat using small bulldog clips from the stationary supplier.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    5 Comments
    Thanks for the tip. I'll be making two of these. One for working with wood material and one for carbon composite material.
    how well does carbon composite cut compared to - say - an equal thickness of acrylic or plywood?
    I love your creative idea! Do you think you could contact me at I write for the magazine publication, Awards and Engraving (A and E) where I provide laser engraving articles. I am presently doing an article on laser cutting tables and some alternatives to the pre-made (and expensive) cutting tables.
    rkorbyl@columbia-awards.com
    Richard Korbyl
    Columbia Awards
    Canada
    Great hack! A word of warning on the pressure washing though, keep the pressure down you can do a lot of damage to the fins of a radiator with a pressure washer. Just ask my wife's car...
    yer - i noticed that in the 1st coupla seconds - shoulda put he warning flag up iguess
