3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
COMBO USB DRIVE WITH ALTOIDS CAN
This is my first instructable and I've decided to make a new gadget with ALTOIDS can. This one is a COMBO USB drive, that you can group all your old flash drives into a one, original and custom shape drive. Enjoy and comment please!
Yet, I am brazilian, so sorry about English language mistakes, ok? :)
Step 1What you need
What you need
- Old Flash Drives (4 is a good amount)
- Empty ALTOIDS can
- Old mouse pad
- DREMEL
- Hot Silicone Glue
70 comments
1-40 of 70next »
Oct 11, 2011. 8:27 AM80$man says:
I like it, I reallly like it!!!
At last I can make use of all the old flash drives in my house! Thank you Cesar!
I would attempt to protect the male ports of the drive, because you removed the casings, they might shear off the PC board.
I feel you on the language front. I'm for South Africa, English is only spoken here in self defence, or by the remaining British! :P
Oct 15, 2008. 7:47 PMYerboogieman says:
You spelled "electric" or "electronic" wrong.
Oct 11, 2011. 8:20 AM80$man says:
You got the idea though right?
Play nice, the guys is a self taught english speaker...
Respect Cesar! Cool Instructable!
May 1, 2011. 10:29 PMcreat0r says:
so wait... how does this work and What is it good 4?
Oct 11, 2009. 7:53 PMSkateboardingForLife says:
 lol, why wouldn't you just set your flash drives in the tin? well i guess thats not as much fun.
Apr 8, 2009. 6:19 PMKasm279 says:
i would put the drive's connectors on the inside somehow, to protect the connectors better and also to make the tin look more ordinary. anyway, nice project!
Apr 8, 2009. 6:21 PMKasm279 says:
OH! the purple kinkston drive is 4GB, right? and also, wat are the other ones?
Jan 30, 2009. 10:23 AMrocketman221 says:
is it possable to put a usb hub in there and sut up the drives to all come up as one big one.
Mar 30, 2009. 4:43 AMcornflaker says:
Ofcourse it possible, the question is can you? :P
Mar 30, 2009. 4:45 AMcornflaker says:
Ahh I didn't read the last part of your comment yeah I think its possible to set them up in some kind of raid configuration but I don't know how exactly, I do remember something from a while ago where this guy set up 4 iPod shuffle's in raid
Feb 27, 2009. 1:20 AMmettaurlover says:
probably.
Oct 14, 2008. 2:48 PMLuminousObject says:
This is a really cool idea. Using a mouse pad for the bottom is a good idea too, a lot easier than trying to cover it with electrical tape.
Oct 15, 2008. 12:37 PMLuminousObject says:
All right. 4.5 stars
Mar 28, 2009. 2:39 PMhollister4400 says:
I say 100 stars I tried it and it really works my husband is a computer programmer he knows all about that stuff
Feb 22, 2009. 3:08 PMaveragejo1111 says:
http://www.hacknmod.com/store/images/uploads/sku_4412_1.jpg
add this to it and ur set. all mounted together
Feb 27, 2009. 1:19 AMmettaurlover says:
never mind; i just got confused.
Dec 12, 2008. 8:20 AMKingJaymz says:
Aside from a couple of small spelling errors (where you said "Yet" instead of "Yes" in step one and you said "space" instead of "spare" in step 6), and I've seen native English speakers be guilty of much more shameful spelling/grammar errors, I was impressed with your command of English grammar and syntax. I'm not likely to build this one, but good on you. A fine idea, and powerful use of a second language. That's impressive no matter where or who you are. Keep studying that English, as it's obviously paying off. Merry Christmas!
Feb 19, 2009. 7:15 AMmettaurlover says:
that's pretty good gor a self-taught language... i've been trying to teach myself a language that nobody speaks and i'm failing at it. specifically, heiroglyphics.
Feb 26, 2009. 10:53 PMfruitkid101 says:
lol-ish
Feb 27, 2009. 1:18 AMmettaurlover says:
and before you as, yes, i'm crazy. and i have a railgun. a big one that makes plasma from its ammo.
Feb 5, 2009. 8:01 AMPseudonym says:
I was thinking it might be nice to switch out the male usb ports for female ones. Then using a male-male cable to connect it. I suppose you could butcher a hub for parts too and only have the one port to connect, but I like the idea of having them separate.
Jan 8, 2009. 3:53 PMtokymaru says:
or put one flash drive on each side of the tin
Jan 7, 2009. 9:04 PMtokymaru says:
you could use 4 of the sandisk cruzers that have the sliders then you could slide one out at a time
Dec 2, 2008. 1:24 AMcornflaker says:
I have a better idea, put a small 4 port usb hub inside it so you only have 1 port to plug in, and they all connect at once
Jan 4, 2009. 2:59 PMamjadk says:
exactly :)
Nov 4, 2008. 4:11 PMmettaurlover says:
(removed by author or community request)
Dec 24, 2008. 12:18 PMspock155 says:
No, because the point is to get a female usb hub connector with the male on the other side :)
Nov 8, 2008. 8:33 AMTh3H4rRy says:
I like this idea, I have several USB sticks, May give it a try. What Dremel cutter did you use?
Oct 30, 2008. 7:58 PMNameless37 says:
That's funny, every person on Instructables that says the originally speak a different language have either none or very few grammar mistakes, well done.
Oct 31, 2008. 12:52 PMNameless37 says:
No Problem
Oct 15, 2008. 2:02 PMmaxpower49 says:
does this only put all of the drives in the same place or do they combine all of space into one
Oct 15, 2008. 12:47 PMcasey321b says:
this is a cool idea and you could label each drive for diferent things like pics on one and so on. also i would think instead of needing a cable why not make each usb drive on a difent side like one on front one on side or you could still use the cable and add tons of flash drives.
Oct 13, 2008. 10:07 PMdarkmuskrat says:
This is very cool. Before I go and build this however, "where is cheapest place to buy 3-4 thumb drives?" (1-2 gigs each...thx in advance guys)
Oct 14, 2008. 12:58 PMjj32x says:
if you live in the uk then novatech have some pretty cheap ones. also i think they do international shipping so even if you dont live in the uk its worth a try.
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:cesarscavone
