C4 PROP
Published
Introduction: C4 PROP
About: i like trains (ASDFmovie quote XD)
I hope you injoy my first tutorial
Step 1: THE RUNDOWN
this is what the C4 looks like use black electrical tape but for the spin i was using this for it needed pink
Step 2: You Will Need
you will need
•tin foil
•legos
•misc wires
•scisors
•electrical tape (or any tape not including clear)
•calculator
•hot glue
•plyars
Step 3: THE BASE
get a 16X6 baseplate and fill it up so its 5X high
Step 4: WRAPING
get some aluminum foil and wrap the base but be carefull with the sides i usually fold them down so they dont look too rattey i also cut off exess foil
Step 5: "GARNISHING"
now this is all up to you add what you want i took a calculator appart and cut a 3X3 piece off that front grate then took the rubber sheet with all the numbers on it and cut out the 3X3 with all the numbers on it i then hot glued that to the plastic grid piece i also painted the grid peice black then i glued the whole lot to the tin foil box and added the calculator screen
Step 6: WIRES
i added 3 wires red white yellow to the top and 2 wires from the keypad to the screen
Step 7: FINISHING
i added tape where neccisary and hot glue sorty the tutorial was not in depth my next will be... happy halloween ^_^
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Outdoor Fitness Challenge
    hey thanks it was my first tut and i made this eatlier its a prop for a movie so i diddnt have many pic. anyways thanks
