CPE133 Digital Clock
2,156
10
Published
Introduction: CPE133 Digital Clock
In this instructable, a digital alarm clock will be made using VHDL and the 7 segment display on a Basys3 board. The digital alarm clock will include features of telling time in real time and setting the time using buttons.
Step 1: Black Box Diagram
Always start by drawing a black box diagram.
Inputs :
clk_in ~ clock signal
btn_min0 ~ button to control first digit of minutes
btn_min1 ~ button to control second digit of minutes
btn_hour - button to control digits of hour
Outputs:
AN ~ 4 bit output used to control each anode of the 7-segment display
DISP ~ 7 bit output of cathodes used to display individual digits in each anode
LED_sec_blink ~ LED light that blinks every second
Step 2: Structural Diagram
VHDL source 1:
A clock divider which is basically a counter is used to slow down the clock to increment by 1 second. This is done by using a counter. The scaling factor for the clock divider is found by dividing the input frequency by the frequency you want. In this case, 100 mHz/ 1 Hz, but divided by two because the clock signal is toggled each half sequence. An led is also added to this clock to show increments of 1 second.
VHDL source 2:
All the clock logic is included in this source. In this case, a digital clock is basically a bunch of counters put together. Each digit of time can be considered a counter. I used seconds as a counter to know when to increment the first minute digit and then using that first minute digit counter to increment the second minute digit. The hours digits are also implemented the same way.
This source also includes the multiplexing of the anodes in the 7-segment display. A different clock divider is used in this source and it is used to display all the anodes at the same time to the human eye. Most logic in this source are if-else statements to display individual values.
Step 3: Clock Divider Source
Step 4: Clock Logic Source
Step 5: Main Module
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    Thanks for sharing!
