3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CRANE GAME
Step 2Control a stepper with joy stick
Next we need to control a stepper motor the potentiometer on the joystick.
Hardware:
Joystick -> Arduino (analog in) -> Arduino (digital out) -> Stepper driver -> stepper motor
I ran this using the EasyDriver from Sparkfun by www.SchmalzHaus.com/EasyDriver
It is well labeled and can run a medium sized stepper motor from the USB power supply. (in this example I am using a NEM17 from Keling Technology).
The screw sheild is by ZachHoeken: http://reprap.org/bin/view/Main/Arduino_Breakout_1_4
Code to control stepper motor from joystick potentiometer
///////////////////////   Arduino ///////////////////////
//******* POT to control a stepper speed and direction ******//
//declare pins
int potPin = 1;
int Step_X = 13;
int Dir_X = 12;
int Enable_X = 8;
//declare values
int Speed_X = 0;       //step speed (delay between steps)
int val= 0;
int j = 0;
void setup() {
  pinMode(Step_X, OUTPUT);
  pinMode(Dir_X, OUTPUT);
  pinMode(Enable_X, OUTPUT);
  //Serial.begin(9600); // note that serial comm can be used to debug
                        // but it will slow down the code and slow down the stepper motor alot
                       //(and be confusing to me)
void loop() {
  val = analogRead(potPin);    // read the value from the sensor
  j = val - 517;  // 517 is center positions - how far from center?
  j = abs(j);      //absolute value
  Speed_X = 70000/j;  //This math inverts the value and scales as needed
                       //(value found through trial and error)
                      // The delay between steps will determine the speed of the motor
                       // So, delay up = speed down
  if (val >= 520){
    digitalWrite(Enable_X,LOW); // enable
    digitalWrite(Dir_X, HIGH);  // Set direction
    digitalWrite(Step_X,HIGH);
    delayMicroseconds(2);
    digitalWrite(Step_X,LOW);
    delayMicroseconds(Speed_X);
  if (val <= 510) {
    digitalWrite(Enable_X,LOW);// enable
    digitalWrite(Dir_X, LOW);  // Other direction
  if (val <=520 && val >= 510) {
    digitalWrite(Enable_X,HIGH);  // disable the stepper motor if the joystic is in the center
7 comments
May 9, 2012. 3:56 PMyel-shourafa says:
sorry i forgot to say : As you know the two POTs will be the joystick ;)
May 9, 2012. 3:53 PMyel-shourafa says:
yeah me too i have to control two steppers which have 20 n.m torque '' big motors '' and i have the stepper drivers.
the motors are installed in a 4 wheeler cart.
i made a code to control the cart forward and backward using the motors+drivers+Arduino uno+potentiometer
and then i made another code without the potentiometer
using 3 Arduinos ( 1 master and two slaves) each slave is connected to a motor
the code is to apply speed to one of the motors for ex 10 rpm and the other motor
5 rpm .. just to make the cart turns left or right ...
THE QUESTION NOW WHAT IS THE CODE FOR THE STEERING USING THE POTENTIOMETER ??
there will be 2 POTs one for steering and the other for moving.
PLEASE HELP !!!
Mar 30, 2012. 1:08 AMjuande3003 says:
Hello,
I need your help, I'm doing a project similar to yours, a pan tilt head and I need to control two stepper motors with a joystick.
Can you help me with the code? How would two stepper motors?
I'd appreciate if you can send photos or a wiring diagram.
Thank you very much.
Apr 3, 2012. 5:36 AMjuande3003 says:
Yes, I need to do it with stepper motors, is difficult to code for two engines?
May 8, 2012. 1:21 AMjuande3003 says:
Thanks for responding,
I like to use stepper motors because they have strength and are accurate. Project where you use your joystick, you use a stepper motor, could you help me with the code to use 2 stepper motors?
I know nothing about programming, so I ask for help.
Thanks for everything,
Greetings.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:marc.cryan
Looking for access to land or water in Boston Metrowest area.
