Step 31Code using switches
Since this controller is just a bunch of switches, we can throw away all the code that had to do with the potentiameters that were in the thumb joysticks. This means that we won't have control over the speed.
Here is the controller in action:
Here is the code to run the Crane Game using the Leap Frog controller. This just uses 6 push bottons to control the stepper motor and the two DC motors.
//////////// Arduino Code ////////////
// Speeds
int Delay_X = 1000; //step delay: microseconds (up delay = slower speed
int Speed_S = 255; // spindle speed 0-255
int Speed_C = 255; //clow speed 0-255
//STEPPER PINS
//Outputs
int Step_X = 13;
int Dir_X = 12;
int Enable_X = 8;
//Inputs
int Left = 16;
int Right = 17;
// variables
int val_Left = LOW;
int val_Right = LOW;
//SPINDLE PINS
//Outputs
int Dir_A = 4;
int Speed_A = 5;
//Inputs
int Up = 14;
int Down= 15;
//variables
int val_Up = LOW;
int val_Down = LOW;
//CLAW PINS
//Outputs
int Dir_B = 7;
int Speed_B = 6;
//Inputs
int Open = 18;
int Close = 19;
//variables
int val_Open = LOW;
int val_Close = LOW;
void setup (){
// setup up stepper pins
pinMode(Step_X, OUTPUT);
pinMode(Dir_X, OUTPUT);
pinMode(Enable_X, OUTPUT);
pinMode(Left, INPUT);
pinMode(Right, INPUT);
//setup DC motor A pins - for spindle
pinMode(Dir_A, OUTPUT);
pinMode(Speed_A, OUTPUT);
pinMode(Up, INPUT);
pinMode(Down, INPUT);
//setup DC motor B pins - for claw
pinMode(Dir_B, OUTPUT);
pinMode(Speed_B, OUTPUT);
pinMode(Open, INPUT);
pinMode(Close, INPUT);
void loop(){
// STEPPER READ AND CONTROL //
val_Left = digitalRead(Left);
val_Right = digitalRead(Right);
if (val_Left == HIGH){
digitalWrite(Enable_X,HIGH); // enable
digitalWrite(Dir_X, HIGH); // Set direction
digitalWrite(Step_X,HIGH);
delayMicroseconds(2);
digitalWrite(Step_X,LOW);
delayMicroseconds(Delay_X);
if (val_Right == HIGH){
digitalWrite(Dir_X, LOW); // Set direction (other direction)
if ((val_Left == LOW) && (val_Right == LOW)) {
digitalWrite(Enable_X, LOW); //stepper off
// SPINDLE READ AND CONTROL //
val_Up = digitalRead(Up);
val_Down = digitalRead(Down);
if (val_Up == HIGH){
digitalWrite(Dir_A, HIGH);
analogWrite(Speed_A, Speed_S);
if (val_Down == HIGH){
digitalWrite(Dir_A, LOW);
if ((val_Up ==LOW) && (val_Down == LOW)){
analogWrite(Speed_A, 0);
// CLAW READ AND CONTROL //
val_Open = digitalRead(Open);
val_Close = digitalRead(Close);
if (val_Open == HIGH){
digitalWrite(Dir_B, HIGH);
analogWrite(Speed_B, Speed_C);
if (val_Close == HIGH){
digitalWrite(Dir_B, LOW);
if ((val_Open ==LOW) && (val_Close == LOW)){
analogWrite(Speed_B, 0);
Add Comment
