For beginners an armature can seem complicated and overwhelming not knowing where to begin. This is a simple system that works quite well and can make an armature in a relatively short amount of time (usually 30 minutes for a 12" armature!)
There are some clays out there that are self-supporting and therefore do not require they use of a support armature. These materials are clay/wax hybrids that are light in weight and fairly rigid when cool like Castilene, which will be covered in another segment.
Remove these ads by
Signing UpStep 1PROPORTIONS
Also a child will be quite different in proportion to an adult& so on and so forth. Proportion can make a figure more or less heroic according to how many heads tall he/she is. For our purposes proportions are measured by using the head as the unit of measurement. From this unit we can find the measurements for the rest of the body. The average human being is 7 1/2 heads tall meaning that if you were to divide the person using the measurement of their head you would find that it would fit 7 1/2 times their body in height. From this there are other measurements that we can find but for the time being this is really the most important aspect you need to understand.
For sculpting you will find that 7 1/2 heads tall, although correct, can make a figure reduced to scale look a little dumpy. This is simply an illusion caused by the fact that you are sculpting something at a reduced scale from the real thing. This is especially true for female figures. In fact you can extend the legs on female figures a little to make sure they look graceful and elegant. In the end though proportion comes down to personal tastes so once you learn how proportion works you can then modify it to achieve the results that most appeal to you.
All though I believe that the one he's using is from this book: www.amazon.com/Figure-Drawing-All-Its-Worth/dp/B00005VWK3
I'd say don't worry too much about exact gauges. If you can find something that eyeballs at a similar thickness, it'll work just as well.
In my experiece, copper and brass wires have a springyness that makes them less ideal. When pressure is applied to the clay with a tool, a copper or brass armature tends to give and then spring back instead of holding stiffly in position, making sculpting more difficult. Brass is stronger than copper or aluminum, but in armature terms that just means it will flex further than copper before bending.
Aluminum by contrast has almost no "spring", though the trade off is it does actually bend easier (i.e. where copper would flex before bending, aluminum just bends right away), so you sometimes have to use a slightly thicker gauge than you might with copper or brass.
I use a resin called SC 320 by smooth-on. You would have to look on their site for a distributor near you. They have silicones as well as other resins to choose from.
I prefer more modest boobs personally...lol! :D
Claudio
