CRT oscilloscope (more of an audio/visual display)
This instructable has been removed by the author.
45 comments
Sep 2, 2009. 2:07 AMDjFluorescent says:
this worked great for me. but then i ended up breaking it doing some experimenting.... oopz.
Sep 2, 2009. 1:19 PMDjFluorescent says:
i saw some ppl on you tube that did this with a crt (computer) monitor. i'm going to try that since i have run out of breakable TVs... :)
Sep 2, 2009. 9:06 PMDjFluorescent says:
it worked with a comp moniter. only you can only get a virtical line.... horizontal didn't work.
Aug 6, 2009. 1:25 PMmark28 says:
i`like to built a osciloscope to prove electronics parts in my car o diferents sensors can i do that with this project?
Aug 1, 2009. 1:00 PMtimbob says:
Thanks for this instructable! mine basically works now :D. Only, the horizontal line is really short. Is that the part where i have to mess with V-hold or H-hold or something? that part wasn't really clear for me.. Also, i can't seem to find either of those things on the tv.. Could it be on the circuit board somewhere? what do i look for?
Aug 2, 2009. 7:41 AMtimbob says:
That worked perfectly! Thanks! it's looking awesome :D
Jun 22, 2009. 1:07 AMcharlieb000 says:
i disconnected a coil and the beam went off ! i know i need to control both coils so is there a way around that? it is a small 12v TV (B&W)
Jun 29, 2009. 2:59 AMcharlieb000 says:
hi, i have done a more permanent modification, and i have found: 1: the light turning off when i played with the coil, well it didnt go off it went dim. and when i switch from TV to scope there is a bright stripe before it goes dim, maybe the brightness of the dot is dependant on the draw of the coil... 2:when i said that it lacks resolution, what is really happening is that the electron beam is flashing on and off on mine and now i have put sound into my coil i can see plainly that my waves are dotted.what can i do to the beam to keep it on (and as bright as before) 3: according to wiki, there is lead in the glass to reduce the xrays, more rays in color tvs (higher voltages). cb.
Jun 30, 2009. 12:45 AMcharlieb000 says:
i think it has something to do with the lower current draw causing a voltage change because when i have the tuner on a chanel it goes to white noise when i flick the switch to change the coil over. v hold may work too i kno it will go brighter when the beam slows (Another mod).
Jul 30, 2009. 4:15 AMCybot Rules says:
hmm, if it Dependant on whats being drawn from the circuit could finding the resistance of the coil and putting a resistor of that rating or similar work?
Jul 30, 2009. 7:40 PMcharlieb000 says:
i did a little research on crt screen and there is two anode grids, one for focus one for accelerating. i suspect that the focus is now out so if i add some components in i could refocus it when i change the switch to scope without wasting some power - the beam is a little fat :) however (i think) the wire for accel is connected to the brightness and the other is connected direct to the transformer (no control on trans - its a 12v) so may need break that. also i might have solved the dotted line problem and that is to simply disconnect the signal that is effecting the flow of electrons to the cathode ray - so disconnecting the capacitor should work...
Jun 22, 2009. 3:47 AMcharlieb000 says:
vhold works but the display is dim and lacks "resolution" (voltage rise lines have some grey areas in them) so i cant see high frequencies
Jun 22, 2009. 3:08 AMcharlieb000 says:
i think i made an error (that test was ages back), it works now (maybe you should do it when its off :P) well it appears i have to have a vertical scope as the knob at the back (vhold) appears to altr the flash rate. well if i get it done it makes a good portable :D id still like to use it as tv so i wont grafitti a grid on it
Jul 22, 2009. 11:45 PMNinquetasar says:
I tried this today, but when I switched it so it was vertical going into horizontal, I got a small vertical line that barely moved to the sound. Any Idea as to what's going on? Also, how do I adjust the V hold and H hold? Thanks!
Jul 23, 2009. 8:54 PMNinquetasar says:
Thanks! You're actually helpful the other person who posted something similar just wished me luck. I'll try it! If I adjust the v-hold will I get more than the boring stuff?
Jul 30, 2009. 4:11 AMCybot Rules says:
You should, it all depends on the tv/crt make
Jul 2, 2009. 7:11 PMscgtrp says:
Just did this with an old 5-inch black and white TV my neighbors gave me. Haven't gotten around to hooking up any audio to it yet, but if I play some static from the airwaves, the line does jump a bit, so I assume I did something right. One question though: any idea how to decrease the brightness of the line? When it's not moving at all it's so bright it's almost blinding, and I have the TV's brightness all the way down. I assume it'd be as easy as a couple of resistors in the right places, but I don't know much about CRTs so I wouldn't know where the "right places" would be. Also, I didn't have to tap into the supply lines, all I did was disconnect the two vertical deflection wires from the board and connect them in parallel with the TV's speaker. Unfortunately the amount of vibration in the line varies with the volume now, but I suppose I could just call that a feature. :-) Looking back I wish I'd done the pulsing from the center style instead, but now I'm out of electrical tape. :-( And, uh, on step 2 are you actually suggesting that I stick my hand inside a powered-on TV with a battery?
Jul 4, 2009. 9:01 AMscgtrp says:
The brightness knob (on the back, not inside) is already all the way down.
You may be (probably are) right about the horizontal line thing, I only tested this with TV static (the TV has a builtin radio, but I stupidly forgot that the TV and radio can't run at the same time while I was building this) and it looked like it was trying to make waveforms, but I could be wrong. I found the configurations page a bit confusing, but reading it again I think I see where I went wrong. Thanks for that.
Now I just have to find a spare audio jack, or a RCA audio cable, to hook it up to a real sound source. That, or work out how to make the radio and TV turn on at the same time.
Jul 4, 2009. 9:57 AMscgtrp says:
Awesome, I see some clear waveforms there after wiring it up the other way. Thanks!
Jun 21, 2009. 8:00 AMrobot797 says:
does this work on old pc monitors as well?
Apr 10, 2009. 1:08 PM12V says:
DANGER do not let the electron beam point off the screen as there is no phosphor to trap x-rays and may damage the tube! try to keep the beam on the phosphors.
Jun 5, 2009. 9:51 PMDerin says:
i think x-rays form when electrons get stopped on their path.But,the monitor shuts down if it detects X-rays.
Jun 18, 2009. 6:38 PMwelder guy says:
HOW HOW HOW????!!!!!!!! does it have a hidden geiger counter!!!!!! how does it detect x-rays!!!!!!!! please reply i'm curius and have a love of radiation and electronics!!!!
Jun 18, 2009. 10:03 PMDerin says:
If you want the truth,I don't know either :)
Jun 15, 2009. 9:39 AMBongmaster says:
looks fun :3
May 1, 2009. 3:38 PMXellers says:
This is a fun project - I made one a few months ago. Can you please include some sort of schematic or other diagram - it would make it much easier.
May 3, 2009. 9:41 AMXellers says:
I never actually used these instructions, I found them elsewhere. I like how you tried to make a good picture of it all, but it is a bit too confusing. Try using some sort of circuit drawing software.
Apr 11, 2009. 3:43 PMnickk says:
interesting project but your pics are so blured we can't see anything, maybe u can include some drawing explaining how to connect the horizontal and vertical cables and with what exactly.
Mar 9, 2009. 5:41 AM-Cry_Wolf says:
THERE'S MY CHIPPY!
Mar 4, 2009. 4:23 AMPKM says:
To the more passive-electronics-savvy: could you feasibly put together some sort of LRC circuit that would shift the phase of the sound signal, use that to drive one coil and the plain signal to drive the other to get some sort of lissajous-style squiggles? Actually I don't see why connecting the signal to the X and Y coils gives a circle- wouldn't it just be a diagonal line? Or do the coils already have lag because of different inductances or something?
Mar 4, 2009. 4:11 AMNachoMahma says:
. Nice job.
Mar 4, 2009. 2:37 AMlemonie says:
I was thinking of doing exactly this myself, so I appreciate seeing it! L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:The 4th Doctor
