3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CRX Climate Control Plate Installation
This write up covers the installation of the climate control cover as sold by Todd (CRX Toad on Honda-Tech, stang65fst on Ebay. Beware of imitations, we are the original!). It gives your broken climate control a new look without spending hundreds of dollars on a new unit. It is not intended to provide structural support to the climate control unit; it is only a cosmetic piece. If your climate control unit is damaged or broken, it must be repaired prior to using the cover. This write up will detail the removal and repair of a damaged unit so the cover may be installed.
This repair was performed on a 1991 Honda CRX Si. Other years or trim levels may be different. Your mileage may vary, parental discretion is advised. If you are unclear or uncomfortable with any procedure in this write up, seek outside assistance, either from the Helms manual or an *experienced* friend.
If you don't have a climate control plate and are interested in ordering one, contact Todd at xmustang1965x@hotmail.com, on Honda-Tech through his screen name, CRX Toad, or on Ebay by the seller name stang65fst.
Step 1Things
Tools Required:
#1 Phillips Head Screwdriver
#2 Phillips Head Screwdriver
Small Flat Head Screwdriver
Climate Control Cover Plate
2 Part Epoxy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:drdisco69
