CSCI-1200 Project 1: Morse Code
Published
Introduction: CSCI-1200 Project 1: Morse Code
In this lab you will be using pushbuttons, a LCD screen and an LED to display Morse Code values for all letters in the alphabet.
Hardware you will need:
1. Arduino Uno
2. LCD screen
3. Pushbuttons
4. Potentiometer
5. LED
6. Breadboard
7.Wires/Connectors
Libraries Needed:
1. LiquidCrystal
Step 1: Connect LCD Screen
Connect the LCD into the Breadboard. The LCD's pin will be connected to the Arduion in the following order:
  1. Ground
  2. Power
  3. Pin 11
  4. Pin 10
  5. Pin 9
  6. Pin 8
  7. Empty
  8. Empty
  9. Empty
  10. Empty
  11. Pin 7
  12. Ground
  13. Pin 6
  14. Potentiometer (Connected to Ground and Power)
  15. Power
  16. Ground
Step 2: Add a Pushbutton
Insert the first pushbutton into the breadboard. The pushbutton is connected using two jumper wires and a 10k Ω (ohm) resistor.
  1. Place one jumper wire on the bottom left side of the button and connect to the power rail.
  2. The second jumper wire will be connected to port 2 of the Arduino.
  3. The resistor will be connected on the bottom right side of the button and the ground rail.
Step 3: Add Three More Pushbuttons
Follow the same steps from Step 2 to add three more push buttons to the breadboard. These three buttons will be used to input different letters from the alphabet: button 1 inputs A-J; button 2 inputs I-R; and button 3 inputs S-Z. The fourth button will be used for an Enter button.
Step 4: Connect an LED
An LED of any color will be used to display the Morse Code value of the letters.
  1. Place the LED anywhere on the breadboard
  2. Connect a jumper wire from the ground rail to the bottom lead (-) of the LED
  3. Using a 220 Ω (ohm) resistor, connect the one end to the top lead (+) of the LED and the other end will be connected to Pin 12 of the Arduino.
Step 5: Morse Code
Morse Code is a form of transmitting information as a form of tones, lights, or clicks. An LED is used to accomplish this in this lab. Each letter of the alphabet is represented using either a short blink, called a dot, or a longer blink called a dash. The code for this lab sets a dot to be 300 milliseconds and a dash to be 900 milliseconds.
Image Source: https://www.schoolofsurvival.com/wp-content/uploads/2015/09/morse.jpg
Step 6: Code for Morse Code Display
Attached is the 1200_Project1_MorseCode.ino which contains all code needed to convert a letter selected by a push button to Morse Code shown on a LED; as well as, displaying the chosen letter on the LCD screen.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    Thanks for sharing :)
