CUBIC METER (arduino + Hc-sr04 Sensors)
2,374
21
6
Published
Introduction: CUBIC METER (arduino + Hc-sr04 Sensors)
About: Technology research and automation designer
Uploaded project was designed and programmed by Rodrigo Mejías (Santiago-CHILE).
The product consists of measuring from a simple linear distance, square meters and up to cubic meters. Since we are using HC-SR04 ultrasound sensors, distances should not exceed between 3.5 meters and 4 meters long,and especially there should be no obstacles in the line that is registering the measure
According to the measurement that we select in the TFT screen menu, the LEDs will begin to flash indicating where each sensor should point, so that each distance registers the angle for square meters, cubic meters, or simply linear distance. After that, just make click on center of ROTARY ENCODER to Start collecting ("MEDIR option") each distance. An single 3-axis graphic will show each measure and confrimed by each LED that stays ON. And according selected Option in menu Mts2 or Mts3, results will be shown on top right corner.
Step 1: Tools and Materials
MATERIALS
1 Arduino NANO
3 HC-SR04 Sensors
1 TFT SPI 1.44" 128x128
1 Rechargable cell (18650) 1200mA
1 Battery charger (mini USB input)
1 Dc-Dc booster 3.7V to 5V
TOOLS
Laser cutting MACHINE
Machining Bench
Soldering Iron
Plastic adhesive
Step 2: Schematics / Plane Cutting Pieces & ARDUINO Sketch
Step 3: Full Sides CUBIC View
General view of assembled CUBIC and a couple more pics to show inside wiring.
Suggestions are welcome
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    6 Comments
    Hello, your project is very good!
    I would like to ask you to replace the sensor with three GY30 modules (IIC light sensor) to detect the two-dimensional plane?
    Hi.
    Do you mean to make same cube but with GY30 sensors?.... If it is, I think is very possible to do so. From that point of view, you just need to replace HC-SR04 code lines for the GY30 commads to adapting CODE and measuring formula to read (Single line, Doble Axys or 3 axys dimension).
    In spite of HC-SR04 can read close to 3 or 4 lineal metres, I´m not sure how long GY-30 can read through light intensity.
    Best regards.
    Rodrigo
    Hi,
    Thanks for the advice, I'll keep it in mind.
