Step 6Pocket Key Screw Hole
1. Drill a through hole just large enough for the screwdriver tip, and the screw shaft to fit through, but not the screw head.
2. About half an inch below that, drill a larger hole that the screw head can fit through. Do not drill all the way through. I wrapped tape around the drill bit to limit the drill depth. It needs to be deep enough that there's about a quarter inch of wood between the base of the screw head and the surface of the wood.
3. Using the router bit and attachment on the rotary tool, set the depth to the bottom of the large hole, and route a path between the small and large hole that is tangent to the small hole.
4. Now, attach a slot cutter bit that fits inside the big hole to the rotary tool. Set the depth of the slot cutter bit to about 0.15 inches. You will be cutting a pocket behind the slot for the screw head to fit in.
5. Insert the slot cutter all the way into the large hole. Follow the perimeter of the slot with the shaft of the slot cutter. This will be the inside surface on which the screw head will apply pressure.
6. Change the slot cutter depth to the depth of the large hole, and repeat step 5. There will probably be a sliver of wood left in the pocket. Move the slot cutter in and out to clean out any thin walls left in the pocket.
comments
Add Comment
engineerable (author)
says:
Add Comment
