3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cabinet for American Girl Dolls
Step 5Attach vertical divider to shelf
Once the vertical divider has been cut, check the fit in the unit by putting in the shelf and vertical divider. Assuming it fits well, pull the shelf and divider back out and affix the divider to the shelf. The cut edge of the divider should be the edge that sits in the channel in the top panel. The factory edge should be attached to the supporting shelf. I countersunk two #8x1" screws from the bottom of the shelf into the divider. The divider needs to be in the center of the shelf, flush with the rear edge. A clamp and flat carpenter square make it much easier to ensure that the divider is centered and square.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:WilyHacker
