3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cable: MintyBoost to Samsung D*00 Cell Phone
Samsung D series cell phones have some problems with USB charging, which cause them to not work with the excellent MintyBoost USB charger (Edit: This may be on faulty phones only, with broken ICs. Reports of these kind of problems stretch back to the D500, but are clouded by forum chatter).
This cable will enable you to charge a D series samsung from the minty (Tested: D900, Should Work: D800, D820, E780, E870, P300, P910, P920, T809, Z540, according to pinouts.ru).
The method is a little crude, but it should work for earlier D*00 models should they present similar problems. Get the right charger though; they have 18 pins out instead of 20.
Step 1Tools, materials, and background.
Tools and materials:
Soldering Iron
Solder
Wire Strippers
Heatshrink tubing
Third hand tool
Type A male USB connector (Cannibalised from spare lead)
Spare mains charger for phone
I found that a D900 would not charge from a properly assembled MintyBoost, and this vexed me. The poor battery life when using it as a DAP was the main reason I got a Minty :/
It would charge for three seconds, then stop. Doing this with the phone powered down elicited the message "USB Charging Not Available", even though the presence of the 5 volt USB power was causing the screen to stay powered on.
Some Samsung phones have problems charging via USB, even though they're supposed to be able to. Reasons for this in forum chatter range from faulty ICs to incompatability with USB 1.1 hosts.
The MintyBoost simulates a USB 1.1 host with a 3.3v pull up on D-, putting the pullup on D+ causes it to appear as a USB 2.0 host.
First step was to scavenge USB parts and make a dongle, with which I could swap pins around. Making the mintyboost appear as a USB 2.0 host didn't make any difference. I also found that with the USB 2.0 ports on my desktop PC, the phone would give a charging indicator perpetually, but in fact not be charging at all. Mains chargers work just fine, but USB power is screwed.
Grr! Silly Samsung. Should be simple!
11 comments
May 24, 2011. 10:14 AMsamyuranun says:
full option
May 23, 2010. 11:01 PMcellphones4us says:
hi.
Good  information, really fantastic, is it work for samsung only or any other mobiles, I am using Nokia, i will check it on my mobile. Thanks for sharing information with us.
Aug 8, 2009. 9:15 AMpancho del rancho says:
worked for my emerson mp3 yay i just need to put it in my altoids but yay
Sep 1, 2008. 1:48 PMacaz93 says:
This trick also work with sony ericsson phones , once they are connected to the minty , they try to go to usb transfer mode , and they don't charge , with this , now they do charge
Jan 30, 2007. 5:59 AMtechnophobe says:
fantastic - this works a treat and only took me 5 minutes. I used the stock mains power that came with my D900 (never charge my phone at the wall anyway). I connected the unshielded to USB black and the white shielded to USB red. Phone charges from USB on my laptop every time now without "USB charging unavailable". Piece of cake - thanks for your excellent write up.
Dec 12, 2006. 10:22 PMCrash2108 says:
That kind of plug is not in my pocket ref. What kind is it?
Dec 17, 2006. 3:43 PMCrash2108 says:
No I mean the electrical outlet.
Dec 13, 2006. 2:53 PMpinski1 says:
I've got the same phone, and it will also charge thought the USB cable supplied, maybe you've just got a buggered cable?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:Nachimir
I live in the UK, and work for a games consultancy. I used to take my toys apart and put them back together when I was a kid, nowadays I try to do the same with emotion, motives and culture. I also...
more »
