Cable Repair
Introduction: Cable Repair
Every time I get a new phone charger or cable, I run into the same problem where the wires get exposed and frayed. This normally results in the charger being thrown out and the purchasing of a new one. This set of instructions is meant to show how these cables can be repaired with the right tools.
Materials Needed:
  • Safety Glasses
  • Soldering gun
  • solder material
  • heat shrink
  • heat gun
  • wire cutters
  • wire strippers
1. Heat guns can reach temperatures over 400 degrees Fahrenheit and can be extremely dangerous
2. Soldering irons melt the material at very high temperatures and can cause injury if not used properly
  1. Cut wire
  2. Strip wire
  3. twist wire together
  4. solder wire
  5. heat shrink wire
    1. individual wires
    2. entire wire bundle
Step 1: Cute the Wire
Cut the wire at the point where the fray is present
Step 2: Strip the Wire
Stripping a wire means to remove the plastic coating surrounding the metal wire. Use the wire strippers to cut the plastic around the outside a pull off the outer coating. Next use the wire strippers to take the plastic of the small individual wires.
Step 3: Solder the Small Wires
WARNINGS: The soldering gun gets very hot and can cause burns.
1. Heat up the solder material using the tip of the soldering gun and let the metal drip onto the wires. This will fuse them together. Do this process for each of the small wires
Step 4: Heat Shrink
WARNING: Heat guns can cause serious injury if not used properly
  1. Place the plastic heat shrink around each of the small solder points
  2. Use a heat gun to shrink the plastic until a clear resin is seen coming out of both sides of the heat shrink
Step 5: Heat Shrink Part 2
Once the wire has been fixed, one last piece of heat shrink must be applied to make sure that the wire is secure and does not become damaged again. Place a final piece of heat shrink around all inside wires and use a heat gun to secure.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    Is it a Weller WTCPS soldering station?
    Hi. I forget 3 times of 10 to put the "owerlapping" shrink at first on the cable :) :) as You did forget it here :). rafununu says absolutely Right: " Shift cutting and stripping from one to the next wire ,doing like this will drastically reduce the diameter of the repaired cable" that allso reduces the risk of "short" if the "shrink isolation" brakes.
    Shift cutting and stripping from one to the next wire, doing like this will drastically reduce the diameter of the repaired cable.
    How do you get the heatshrink over the wires that have already been soldered? I think you missed a step, you need to put the heatshrink onto the wires before you solder them.
    I have had to do this so many times. It takes some time to do it properly but it sure beats having to spend a bunch of money for a new cable.
