3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cable and Magnet Bulletin Board
Here is a way to make a place to hang papers, pictures and other random stuff using just some steel cable, a few magnets and some basic hardware. This project takes about 20 minutes to put together and you can pick up most of what you need at the local hardware store. While the project doesnt require much building experience, you will need a cable cutter, needle nose pliers and a drill to put this thing together.
When your done you'll have a lightweight, semi-portable, semi-hip way to hang up all the extra papers lying around - or bacon adhesive bandages as the case may be.
This project is based upon something I saw in a museum gift shop which closely resembled this. But why pay money for what you can build yourself and customize to you own needs?
Step 1Gather Materials
Gather Materials
First you will need to gather your materials.
1. Steel cable - I picked up about 8 feet of 1/8" steel cable from the hardware store at about 18 cents a foot. You can use thicker steel cable - but unless your going to be suspending a whole lot of paper (more than a couple hundred pounds worth) the 1/8" braided cable is fine.
2. Magnets - I had some old magnets lying around that I use as grill connectors on speakers so I just used those. If you want to buy some nice magnets that would work well you can get some at http://www.kjmagnetics.com/. They offer a whole bunch of different types of neodymium magnets from 6 cents a piece up to 1 dollar a piece. Any disc magnet around a 1/16" to 1/8" thick will have plenty of holding power for a regular paper. If you plan on going through some heavier stock or want to hang some larger objects it would be best to get a bigger magnet - at around 1/4" they start getting really strong.
3. Cable clamps - These are available where the cable is sold in the hardware store and you should get the size that fits your cable. I got 1/8" clamps for 1/8" cable.
4. Screw Eyes - The screw eyes also come from the hardware store and are just your basic screw eyes for wood. 1/4" x 1.5" screw eyes are plenty strong if your hanging them in wood. If your walls are drywall or plaster you should pick up some plugs for the screw eyes and sink them in first so they have something to grab on to.
11 comments
Apr 14, 2010. 11:05 AMinkstainedheart says:
Great instructable, and I love that you have bacon bandaids in the picture!
Feb 28, 2007. 6:02 PMewilhelm says:
I made one of these in my office today! I just ran the steel cable around some pipe mounts already bolted to the concrete and put the turnbuckle near the ground. Small magnets hold single pieces of paper with ease.
Dec 13, 2006. 11:35 AMwillyyam says:
Tightening is more easily done with a small turnbuckle. These come in many forms, including very slick ones for tensioning cable. These take a cable in each end and holds that cable with grub screws, and then the central barrel turns to lengthen or shorten the buckle.
Neat concept, and well explained.
Dec 17, 2006. 1:38 PMvatosupreme says:
Make sure you don't overtighten the turnbuckle. When the screws are in wood, sometimes you can tighten the cable up too much and the screws start to lien in and pull out of the wood. Also, for this application, you should be able to use a friend to get the cable tight enough. A turnbuckle will clutter the contemporary look you are trying for.
Dec 14, 2006. 11:22 PMtremor7 says:
Bulletin board 2.0 Great job!
Dec 13, 2006. 10:22 PMbongsanvictores says:
Great idea- the only problem is that officemates might also want one for themselves and that means more frigate-rigging work. If could get hold of a three-strand cable- I think an eye splice would be neater, doing away with the clamps (another instructionable?)
Dec 14, 2006. 11:29 AMQuill says:
An eye splice is a way of splicing a stranded rope or cable end back on itself to produce a loop. See, for instance,
http://animatedknots.com/splice/
Dec 12, 2006. 4:33 PMtheRIAA says:
coolio
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
875
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
