iImage Information
One does not wish to have one's servants tire from hand carrying a filled multi-gallon garden sprayer to tend the many acres of roses on one's estate. Build a cart that will roll the sprayer, and the servants will still be fresh at the end of the day so you can work them well into the night. Most parts can be found in scrap bin. To see my related Instructables, click on "unclesam" just below the title above or in the INFO box to the right. On the new page that appears, repeatedly click "NEXT" to see all of them.
Unclesam
Step 1Bottle removed
iImage Information
Main chassis is 2X4 12" long. Upper wood adapter is 1-1/2" by 1-1/2" by 9-1/2" long, corners rounded. Wooden towing rod is 3/4" dia by 15" long, chosen because crutch tip just happened to fit tightly onto it. Metal uprights are electrical conduit that measures about 5/8" outside diameter, 24" long each. Foot is the same material, 9" long. Rubber tape is wrapped around the end of the foot to make it big enough to grip crutch tip. Two 10" lengths of water pipe insulation are taped around the metal uprights.
Top Notch bit of kit though, jolly well done.
Cheerio Old Bean.
