Step 5Making the Shroud
haventmadeabombyet's Practical Bottle Cutting
Ojuiceboy09's Bottle Cutting Instructable
Make's Bottle Cutting
If you don't like any of those you can try my instructions
1) Get the bottle you want
2) Put a hose clamp around the part you want to cut
3) Get a Plate Glass cutter
4) Trace one side of the hose clamp with the plate glass cutter until you have a deep, straight groove.
5) Heat the groove up with a candle or very carefully with your blowtorch
6) Plunge the bottle into ice cold water
7) Repeat steps 5 and 6 till bottle is cut
8) Sand sharp edges
This skill is an art. The deeper and straighter your cut the better your bottle will break.
Cut the ends off of two bottles that you want to use for the lamp
Tape the end of the bottle up with electrical tape
Put it into the clamps on the tower of the lamp
Move to the next step
(Second best, nichrome wire heating) Score the bottle as you would and, under a trickle of water, make several passes around that line until the cut is complete. Water is messy and electrically dangerous but it quells the glass dust and keeps the cut cool. This method has opened my possible materials to everything from projection tv CRT's to large HID bulbs for my lamp making.
