3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Caffeinated Jello Shots
Step 3Preparing the mixture
This step is only required if using the caffeine pills instead of a pure powder.
A 6 oz Jello package makes about 30 shots. The amount of pills needed depends on the desired caffeine dosage per shot. To make thirty 100 mg caffeine shots a total of 3 grams of caffeine is needed.
If using standard 200 mg pills, 15 will be needed. To grind the pills:
1. If mortar and pestle are available use those to grind the pills, if not place the pills on a sheet of paper.
2. Fold the paper in half, and go over it with a rolling pin or some other dense cylindrical object.
3. Keep rolling until the powder is similar in consistency to cocaine.
4. If using B12, grind some of those pills in to the mixture too. The specific amount of B12 used is not as important as the caffeine dosage. It is more of a season to taste, a few pills for a slight added energy boost or many for full energy double penetration.
3 comments
Aug 26, 2010. 11:18 AMsqeeek says:
Maybe I should snort it...
Aug 26, 2010. 11:48 AMFormatt says:
Of course you can snort it. Take it from me though the drip you get in the back of your throat is not pleasant. However it is a "pick-me-up" since you do absorb things well in your nose. Weigh your pros and cons and exercise caution.
Aug 17, 2007. 9:02 PMmicropreemiemommy says:
Hmmm...I am not sure what the consistency of cocaine is! I am guessing you do? ;)
Mar 31, 2008. 10:53 PMGamernotnerd says:
Yes. About the same consistency of Anthrax. Or just buy some and check
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
